Wife's car is an 07 Caliber. Bottom of the line, manual locks and windows, CVT with 2.0 world motor. Scored an EVIC cluster on ebay (08?), installed it. Expected the odometer to change to the higher mileage and it didn't. Will it eventually? Plus the fuel display says "low fuel" with ½ a tank and no MPG showing. Tried the "press button twice within 3 seconds to reset all" and nothing. Does the headlight off delay just fine, shows outside temp and doors etc.
Bought it mostly for the tach and to watch the gas mileage. Do I need someone with a Starscan/Starmobile/witech to set it?
