1971 340 Owners - What's Wrong With These Pictures? #1521812
10/23/13 12:28 AM
10/23/13 12:28 AM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
First...............
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521813
10/23/13 12:28 AM
10/23/13 12:28 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2......Same car
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521814
10/23/13 12:30 AM
10/23/13 12:30 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Supposedly too late of an SPD for an orange engine?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: 69CoronetRT] #1521815
10/23/13 12:42 AM
10/23/13 12:42 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes sir!
This is the third 1971 340 car I've documented with an orange engine installed way past the orange to blue color changeover (late March/early April or so). This cars SPD is May 21, 1971, yet the engines assembly date is WAY earlier (3373 10,000 day calendar date = Thursday October 22, 1970) and has an original VIN# sequence stamping that matches the cars VIN and fender tag. The other two cars were Demons and were Hamtramck plant cars, this one is the first B-body and the first Los Angeles car I've seen this way.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521816
10/23/13 12:43 AM
10/23/13 12:43 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
VIN#. Car is right here in Spokane!
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521817
10/23/13 12:57 AM
10/23/13 12:57 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Yep they pushed a rack or two of orange 340 engines into a corner and forgot about them till the first week of April, my demon is a SPD of April 2nd with a engine build date of I think November something 1970. You probably have the details of my engine better than I do Scott!
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ademon] #1521818
10/23/13 01:49 AM
10/23/13 01:49 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I see GW340 Windsor "orange" vs. (GM340) Mound Rd. "blue" '71 was the last year for the LA plant. With the plant shutting down/change of engine assembly plants I'm sure the orange VS. blue 340 issue is quite complicated for LA cars.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521819
10/23/13 10:51 AM
10/23/13 10:51 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Yes sir!
Typically issues like this can be explained by some sort of quality control measure that set a component (in this case an engine) aside from the production line for repair or re-work. The engine was likely removed from production at an earlier date. It was then re-worked and finally re-introduced back into production some time later. This type of event was not so uncommon then and still happens today.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: 70gtx440dana] #1521820
10/23/13 11:27 AM
10/23/13 11:27 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Yes sir!
Mine has the sideways X with the Maltese cross and a A4 after the numbers. not sure if something is .010 under i think the Maltese cross is -.010 mains, and an A4 might have meant an oversize bore but not sure.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ademon] #1521821
10/23/13 12:18 PM
10/23/13 12:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ademon, your engine and the other 71 late build demon that has an orange engine have something in common with each other, both engines were built on the same day (Friday November 16th 1970 if I recall,which is my birthday) that makes me think that it was an inventory issue as opposed to a faulty/repaired engine as described above.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ademon] #1521822
10/23/13 04:57 PM
10/23/13 04:57 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
exactly correct!
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ph23vo] #1521823
10/23/13 05:18 PM
10/23/13 05:18 PM
Lansing, MI
Lansing, MI
exactly correct!
Wow....you were there to witness these racks of engines being pushed into the corner.....forgotten about for several months and then being found again?? That is quite a coincidence.
I don't buy these engines as being misplaced as being the gospel truth!!! I still suspect some type of quality control measure took place and the engines were quarantined for a period of time until the issue was resolved. I saw this type of action on a daily basis while working at GM and a couple of large automotive suppliers. However, we will never know what really happened.....will we.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: 70gtx440dana] #1521824
10/23/13 06:46 PM
10/23/13 06:46 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Wasn't there, I was 2yo.. LOL
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ademon] #1521825
10/24/13 06:03 AM
10/24/13 06:03 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Is there any way to re-stamp those numbers just below the left head? Nothing sinister, just the fact that the numbers can barely be read on my block. My VIN is fine...
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: 1972CudaV21] #1521826
10/24/13 10:01 AM
10/24/13 10:01 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No,(good way to ruin your blocks authenticity having been altered though)..........and barely readable is plenty good enough.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: ScottSmith_Harms] #1521827
10/24/13 03:51 PM
10/24/13 03:51 PM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
Yeah, no doubt. All it would be doing is adding an element of suspicion.
Re: 1971 340 Owners - What's Wrong With These Pictures? [Re: 472 R/T SE] #1521828
10/26/13 07:30 PM
10/26/13 07:30 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Hmmm...you make a good point. Maybe I can just do the best that I can to preserve the original numbers.
