68 satellite cruise control #1521524
10/22/13 03:31 PM
10/22/13 03:31 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
i've been searching all over but still cannot find any reference photos on re-attaching the cruise control unit to my car. i've since replaced the old 318 with a 383... all the reference photos i've found online are for post 69 cruise control units which appear to mount differently. unfortunately the unit was unattached when i purchased the car looks like the previous owner restored it. anyone know where i can find instructions or reference photos? thanks in advance!
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: 68 satellite cruise control [Re: maxi333] #1521525
10/22/13 04:08 PM
10/22/13 04:08 PM
Andrewh Online content
Andrewh  Online Content
not sure if this helps.
68 fury
Re: 68 satellite cruise control [Re: Andrewh] #1521526
10/22/13 04:11 PM
10/22/13 04:11 PM
another angle
Re: 68 satellite cruise control [Re: Andrewh] #1521527
10/22/13 04:56 PM
10/22/13 04:56 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Not the best photos but here is the factory cruise on my 70 Charger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 68 satellite cruise control [Re: maxi333] #1521528
10/22/13 08:21 PM
10/22/13 08:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1968 and 1969 cruise systems are exactly the same but completely different than 1970
I am not sure if the C body stuff is same or similar to the B body stuff
Re: 68 satellite cruise control [Re: maxi333] #1521529
10/22/13 09:57 PM
10/22/13 09:57 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I installed factory cruise on my '69 Charger. There were 2 dimples on the inner fender indicating where the factory bracket would have been located/bolted. After drilling out the dimples for the bolts, the bracket fit great. Check your inner fenders to see if there are dimples there.
If there are no dimples, this may help. The mounting bracket is the same for 68-70 B bodies (even though the cruise unit itself changed in '70), so any of those cars/pics you can find will be a help.
Feel free to pm or email me if you have any questions about my install (email is in my profile).
I go to several car shows each summer that are 1-3 hours one way, so the cruise is great to have. If I could not have found enough parts and/or not gotten the factory setup to work, I was going to look at an aftermarket install.
As already mentioned, '68 & '69 are the same cruise systems.
Don't have any pics of my car but here are 2 I found and saved for reference before doing mine.
Re: 68 satellite cruise control [Re: 6PKRTSE] #1521530
10/26/13 04:30 PM
10/26/13 04:30 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
thanks fore the pics folks! i'm starting to get a better idea of where it mounts... thing is it was mounted on the car at one time being that the wiring is there and the cruise turn signal stalk on the column but those holes on the drives side inner fender have never been used???? still have the factory paint over them. problem is the guy i sold my 70 charger to accidentally grabbed my cruise unit and he's out of town. maybe it was added later? hopefully will have some pics for ya soon
Re: 68 satellite cruise control [Re: maxi333] #1521531
11/10/13 10:21 PM
11/10/13 10:21 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
ok so i finally got my cruise unit back and here are some pics... problem is the mount doesn't look like any of the pics i've seen on here. from what i can remember before i replaced the old brake booster is that my mount fixes to where the brake master cylinder mounts to the booster? do i have an after market unit? also not sure where the vacuum line connects or the electrical? any ideas folks?
Re: 68 satellite cruise control [Re: maxi333] #1521532
11/10/13 11:50 PM
11/10/13 11:50 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
The few aftermarket cruise units I have seen do not attach to the speedo cables that way. My guess is that it is off a different year/model. Are there any numbers on the bracket or cruise unit? If you post a pic of the cruise lever it might be a help.
Re: 68 satellite cruise control [Re: moparfan53] #1521533
11/11/13 01:23 AM
11/11/13 01:23 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a pic of the cruise unit on my '68 383 Charger.
Re: 68 satellite cruise control [Re: 6bblgt] #1521534
11/11/13 01:24 AM
11/11/13 01:24 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& the turn signal stalk.
Re: 68 satellite cruise control [Re: moparfan53] #1521535
11/11/13 04:52 PM
11/11/13 04:52 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
hmm there aren't any numbers on the bracket but on the unit it has 2 sets of patent numbers 3298482 and 3444950 but google only pulled an obscure R. S. MUELLER ETAL SPEED GOVERNOR schematic. i'll get a better shot of the cruise stalk tonight. i'm starting to think i might be better off removing the cruise all together?
Re: 68 satellite cruise control [Re: moparfan53] #1521536
11/11/13 05:57 PM
11/11/13 05:57 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
here is the cruise stalk... any ideas folks?
Re: 68 satellite cruise control [Re: maxi333] #1521537
11/11/13 06:14 PM
11/11/13 06:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I know my Charger pic above wasn't much help - here's a pic from a '68 brochure.
Re: 68 satellite cruise control [Re: 6bblgt] #1521538
11/11/13 06:19 PM
11/11/13 06:19 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
ah shoot well it's definitely not that 68 one from the brochure. thanks for the pic!
Re: 68 satellite cruise control [Re: maxi333] #1521539
11/11/13 06:29 PM
11/11/13 06:29 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
It is definitely not 68-70 vintage. I have seen that style before, am guessing mid 70's.
