New Manual Steering Box what fluid?
#152102
11/17/08 08:35 AM
11/17/08 08:35 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I have a rebuilt aluminum manual steering box for my 67 Coronet. What type of fluid do I put in the box? Thanks.
RS23L7 4-Speed
Re: New Manual Steering Box what fluid?
[Re: Mopar_Mike]
#152105
11/17/08 11:44 AM
11/17/08 11:44 AM
RapidRobert
Rick Eberg recommended using some high temp wheel bearing grease melted & mixed in with iirc 85-90 gear oil. I dont remember the exact proportions( I have it copied some where) but it might be online at Mopar Action if a person wanted to check it out.
[Re: RapidRobert]
#152106
11/17/08 12:09 PM
11/17/08 12:09 PM
Posts: 75,068 U.S.S.A.
JohnRR
U.S.S.A.
what are you HIGH ??? where's the link ???
[Re: JohnRR]
#152107
11/17/08 12:16 PM
11/17/08 12:16 PM
RapidRobert
You are thinking that I might be under the influence because of what I suggested or because I did not add the link. come on double R be nice I know you have it in you.
[Re: JohnRR]
#152109
11/17/08 12:29 PM
11/17/08 12:29 PM
RapidRobert
You're almost as bad as I am. When I went to the dealer to get the grease Eberg mentioned they gave me a tube of 4318046 & said that was the superseded # but it was the same stuff. My next manual box I'm going to use his concoction.
[Re: Snoopy]
#152113
11/17/08 06:29 PM
11/17/08 06:29 PM
JohnRR
U.S.S.A.
I wonder why the factory recommended this procedure?
Because that's the EASY way to fill it and it cost less labor wise , which is why the big 3 didn't go bankrupt via the nasty UAW back in the late 60's
[Re: Snoopy]
#152116
11/17/08 07:57 PM
11/17/08 07:57 PM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
I also wonder. EVery one I have seen has had the greyish grease in it. Looks sort of like never sieze.
