Rebuilding front bench seat internals 70 RR #152096
11/17/08 07:41 AM
11/17/08 07:41 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline OP
The front seat on our 70 RR is getting tired internally. The metal mesh, well not exactly a mesh but a back and forth wire that essentially is the support is broken in a couple of places. Is there a source for this? Shipping a different seat here would be very expensive and there are none in the couple of junkyards here. The seat cover is in good shape, it is the internals.
Right now I have a folded over towel over the seat which helps but is obviously a temporary fix.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Rebuilding front bench seat internals 70 RR [Re: David_in_St_Croi] #152097
11/17/08 11:06 AM
11/17/08 11:06 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
David , those are the seat springs , not sold separately that I know of, try and find a seat local that has similar looking springs and swap them to your seat or find one in the states and see if the seller will just send you the springs , use the pass side ones as they won't be as USED ????
Re: Rebuilding front bench seat internals 70 RR [Re: JohnRR] #152098
11/17/08 11:20 AM
11/17/08 11:20 AM
Dallas, TX
70challrtse Offline
super gas
70challrtse  Offline
super gas
Dallas, TX
I need the wire that connects the seat adjusting knobs.
Re: Rebuilding front bench seat internals 70 RR [Re: David_in_St_Croi] #152099
11/17/08 06:44 PM
11/17/08 06:44 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
You can weld those back together fairly easily, which would be a zero cost fix. Otherwise you could try a wanted ad for some parting a seat out.
Re: Rebuilding front bench seat internals 70 RR [Re: NV69B7RR] #152100
11/18/08 08:22 AM
11/18/08 08:22 AM
Thanks for the replies. I like the zero cost fix, especially given where we are located.
70ChallRTSE, I used a piece of stainless steel MIG welding wire to connect the levers, it worked pretty well.
Re: Rebuilding front bench seat internals 70 RR [Re: 70challrtse] #152101
11/18/08 10:16 AM
11/18/08 10:16 AM
JohnRR Offline
JohnRR  Offline
I found one hanging from a hook in the closet in my basement the other day
