Re: outboard carbs on a sixpack setup are not opening up
[Re: 71blackdemon]
#1520695
10/20/13 08:46 PM
10/20/13 08:46 PM
RapidRobert
Take off the covers & you'll see where the diaphram has pulled away from the perimeter (highly likely) so it's not sealing & therefore leaking there or the diaphram has a split somewhere & you'll see it if you take it out of the housing. EDIT Do Buildanothers' test first
[Re: 71blackdemon]
#1520696
10/20/13 09:06 PM
10/20/13 09:06 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
my outboard carbs on my sixpack are not working i checked vacuum to the carbs and it does have vacuum so with the engine not running i opened the throttle on the center carb and i sucked on the vacuum hose to the outboards and the back carb moved very little the front one did not move at all so i ordered new diaphrams i hope that fixes it plus when i was sucking on the vacuum hose i could hear the air flowing through the diaphrams like they were leaking anybody have any input it would be greatly appreciated thanks.
First thing I see wrong is you have the vacuum line connected to the distributor vacuum port on the center carb metering block instead of to the main body.
[Re: 62maxwgn]
#1520697
10/20/13 09:16 PM
10/20/13 09:16 PM
Posts: 278 Kentucky
71blackdemon
Kentucky
I appreciate that i guess the base plate will pull more vacuum thanks.
[Re: 71blackdemon]
#1520698
10/20/13 09:55 PM
10/20/13 09:55 PM
62maxwgn
Blair County,PA
It doesn't go to the base plate,there is another port behind and lower on the main body,the tube may be missing.
[Re: 62maxwgn]
#1520699
10/20/13 10:00 PM
10/20/13 10:00 PM
Posts: 278 Kentucky
71blackdemon
Kentucky
that looks like where i got it at thanks.
[Re: 71blackdemon]
#1520700
10/21/13 11:00 AM
10/21/13 11:00 AM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
While you have the pods off, make sure that the kill bleeds from the pods into the carb throats are clear and that the cork seals are in good condition. I usually change the seals if they are very old at all.
Master, again and still
[Re: 71blackdemon]
#1520701
10/21/13 01:00 PM
10/21/13 01:00 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
I'm thinking no it isn't.... looks like it's not plugged onto the proper tube. The port on the metering block is for the vacuum advance hose and that appears (at least in the pic) to where you have the hose plugged onto. The proper port is on the main carb body about 3/4" behind and below that. Pardon me if I'm wrong when looking at your picture, but if it is in the wrong spot, hooking it up correctly should be an eye-opener when you mash the peddle!!!!
[Re: superwrench]
#1520702
10/21/13 01:46 PM
10/21/13 01:46 PM
62maxwgn
Blair County,PA
Wrong port it would be !
[Re: 62maxwgn]
#1520704
10/21/13 08:57 PM
10/21/13 08:57 PM
Posts: 278 Kentucky
71blackdemon
Kentucky
there is one right below that one and that is where they had it pluged into but it didn't have any vacuum that i could tell.
[Re: 71blackdemon]
#1520707
10/21/13 10:58 PM
10/21/13 10:58 PM
62maxwgn
Blair County,PA
okay thanks i appreciate it.
And once you do that and if you don't connect the vacuum advance,cap that port.
[Re: dogdays]
#1520710
10/24/13 09:08 PM
10/24/13 09:08 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
He's right, the engine has to be under load for the secondaries to open.
Did you hold the stems up so that the edges of the diaphrams are as far out to the edge of the pods as possible when you screwed the covers down?
And which springs are in the pods? They could be so stiff as to completely keep the secondaries from opening, depending on your engine.
Are the little cork seals for the kill bleeds in good shape?
That's all I can think of right now. Good luck!
