Re: PPG Delstar paint question
[Re: 8trackbee]
#1520458
10/20/13 04:16 PM
10/20/13 04:16 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I just did some touchup with Delstar and no hardener, it will dry but takes a little longer.
[Re: 8trackbee]
#1520459
10/20/13 04:20 PM
10/20/13 04:20 PM
Posts: 21,833 Kirkland, Washington
Pacnorthcuda
no hardner in acrylic enamel, can you do that? won't the paint stay soft...
You can, but the result is not nearly as durable as catalyzed paint. The catalyst actually "cross links" the molecules. That means its literally a different finish, and is far more durable. Harder, more chemically resistant etc.
[Re: Pacnorthcuda]
#1520460
10/20/13 09:17 PM
10/20/13 09:17 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Do NOT use DT reducer, it is for urethanes. Chances are you will ruin your paint in a quick and fast hurry. You need the appropriate enamel reducer.
As noted, it will air dry with time. The hardener makes it much faster but is not necessary.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1520461
10/20/13 11:23 PM
10/20/13 11:23 PM
Posts: 1,053 Ont, Canada
gygeneral
Ont, Canada
That's what I have found from google searches but I wasn't sure if it was just a PPG sales gimmick. I will call tomorrow and see if I can get the appropriate reducer. I would imagine I can use anyones reducer as long as its for acrylic enamel, right.
[Re: gygeneral]
#1520462
10/21/13 10:09 AM
10/21/13 10:09 AM
herkamer
Lakewood, Colorado
Correct, I believe any acrylic enamel reducer will work fine. I've used DTR in Dupont just fine. As long as the system is the same, you shouldn't have any problems. Always try to mix a little first to see if it has any weird reactions. I've had paint curdle like bad milk because of old or wrong components.
[Re: Challenger 1]
#1520465
10/22/13 09:45 AM
10/22/13 09:45 AM
gygeneral
Ont, Canada
Don't change the ratio, just don't add the hardener, like said above.
Thanks, I will try that.
