2008 Aspen Gas in Oil #1520396
10/20/13 11:45 AM
10/20/13 11:45 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
My dad is on a road trip and his 4.7 liter started running rough. Pulled into dealer and drained oil to find a large amount of gas in oil. So much, made a mess when drain plug opened. Mechanic said like it was under pressure. Put new spark plugs in it and diagnostics detected bad coil. Installed new coil.
He then drove another 300 miles and runs good now but oil level seems to be creeping up again.
Any common issues here?
What should he check next?
Anyone have same experience?
Thanks for your help.
Re: 2008 Aspen Gas in Oil [Re: CYACOP] #1520397
10/20/13 11:54 AM
10/20/13 11:54 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Not familiar with that car, but if an injector sticks open on a common rail, it will simply keep spraying the cylinder with gas. Not a good idea to drive it like that!
Re: 2008 Aspen Gas in Oil [Re: 300by500] #1520398
10/20/13 02:13 PM
10/20/13 02:13 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
Not familiar with those either, but that can also be a sign of a faulty PCV system.
Facts are stubborn things.
Re: 2008 Aspen Gas in Oil [Re: larrymopar360] #1520399
10/20/13 08:15 PM
10/20/13 08:15 PM
IN
ahy Offline
ahy  Offline
IN
Is it under 100k? If so I believe it has a 100k powertrain warranty. Maybe let the dealer figure it out... and maybe deal with the damaged engine.
Re: 2008 Aspen Gas in Oil [Re: CYACOP] #1520400
10/20/13 09:33 PM
10/20/13 09:33 PM
NY NY
3
340duster340 Offline
NY NY
the only thing i could think is you have a dead cylinder / misfire and its gas-washing the rings.
that is the only way gas could get in the oil that i can think of, from injector to chamber (and no combustion), through rings.
Re: 2008 Aspen Gas in Oil [Re: ahy] #1520401
10/20/13 09:50 PM
10/20/13 09:50 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
It has just over 100,000 miles
Re: 2008 Aspen Gas in Oil [Re: CYACOP] #1520402
10/20/13 10:53 PM
10/20/13 10:53 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
What year?? All OBDII vehicles will flash the MIL when misfires occur. They normally will shut off injectors when that happens also(fuel cut)
Re: 2008 Aspen Gas in Oil [Re: Dcuda69] #1520403
10/20/13 11:25 PM
10/20/13 11:25 PM
Ohio
Todd Offline
Todd  Offline
Ohio
More than likely you have an injector stuck open.
There is probably one that leaks a little after the engine is shut off and all the fuel pressure leaks down that one cylinder.
Sometimes you might notice a slight misfire at startup. It it doesn't misfire long enough for the misfire monitor to pick it up.
What I've done in the past to find those is remove the injectors from the intake leaving them in the fuel rail. Cycle the key on and off and back on a few times. That will pressurize the fuel system.
Then look at the tips on the injectors. If any are wet those are the ones leaking.
