Changing 65 Satellite to Front Disks? #152040
11/17/08 12:10 AM
11/17/08 12:10 AM
Middleton, ID
curleysracecars Offline OP
Middleton, ID
Hey guys,
Looking for a bolt on type of deal from another Mopar car to make the front disk setup on a 65 Satellite. A guy selling one on eBay said he used 76 Charger disk brakes, and everything is bolt on, but you need to keep the lower control arm from the drum brake setup. Does this sound accurate? Any other Mopars that would interchange front disks?
Thanks in advance!
Kyle
Re: Changing 65 Satellite to Front Disks? [Re: curleysracecars] #152041
11/17/08 12:53 AM
11/17/08 12:53 AM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
google "Mopar Action Disc-o-tech"
Re: Changing 65 Satellite to Front Disks? [Re: curleysracecars] #152042
11/17/08 12:59 AM
11/17/08 12:59 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
62-72 B body is a direct swap. I have the entire front suspension/disc brakes from a 72 Coronet under my 65 Belvedere. No muss, no fuss.
Re: Changing 65 Satellite to Front Disks? [Re: nomore65BelvJim] #152043
11/17/08 01:57 AM
11/17/08 01:57 AM
Middleton, ID
Middleton, ID
Awesome thanks guys! Im assuming the master cylinder from the disk brake car is needed as well?
Kyle
Re: Changing 65 Satellite to Front Disks? [Re: curleysracecars] #152044
11/17/08 02:22 AM
11/17/08 02:22 AM
take everything you can from the donor car. use the master for a core and be sure to get the proportioning/distribution valve and the lines in between it and the master.
Re: Changing 65 Satellite to Front Disks? [Re: nomore65BelvJim] #152045
11/17/08 02:34 AM
11/17/08 02:34 AM
Middleton, ID
Middleton, ID
Awesome! Thanks a bunch!
