Carter AFB #3447 #1520322
10/20/13 12:34 AM
10/20/13 12:34 AM
New York, USA
I
Its Not A Hemi Offline OP
I
New York, USA
Carter #3447 AFB.
Need 'factory' Jet Sizes.
Rated at 600 CFM {1 7/16' Primary x 1 11/16" Secondary}
Re: Carter AFB #3447 [Re: Its Not A Hemi] #1520323
10/20/13 04:17 AM
10/20/13 04:17 AM
Cab_Burge Online work
Cab_Burge  Online Work
Carter #3447 AFB.
On which motor, that is the Carter part # for M.W. carbs. for both the 1962 and 1963 M.W. motors, both compression amd HP ratings I'm not sure if it is the same part number for those year 426 wedge single four barrel NASCAR Wedge motors also
Re: Carter AFB #3447 [Re: Cab_Burge] #1520324
10/20/13 09:47 AM
10/20/13 09:47 AM
New York, USA
I
I
New York, USA
Mr. Cab,
It came off of a 1963 426 'Super/Stock Max-Wedge'
I got the Carburetor off of an old 1966 273 Barracuda
''J/S' Stocker Rsce Car' that I found in an old junkyard.
Re: Carter AFB #3447 [Re: Its Not A Hemi] #1520325
10/20/13 11:04 AM
10/20/13 11:04 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Everything you need top know !
Re: Carter AFB #3447 [Re: 62maxwgn] #1520326
10/20/13 11:05 AM
10/20/13 11:05 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
#2
Re: Carter AFB #3447 [Re: 62maxwgn] #1520327
10/20/13 11:06 AM
10/20/13 11:06 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
#3
Re: Carter AFB #3447 [Re: 62maxwgn] #1520328
10/22/13 03:16 PM
10/22/13 03:16 PM
New York, USA
I
I
New York, USA
Thanks 62 Max-Wedge Man,
Excellent information.............
Primary Jets....... .098"
Secondary Jets..... .082"
The paperwork in the car stated that they purchased this from
Spehar's Automotive in March 1966, and it was 're-calibrated'.
