Page 3 of 3 1 2 3
Re: Changing VIN plate to new dash frame [Re: 7812845] #1520237
10/23/13 11:47 AM
10/23/13 11:47 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
My thoughts exactly,and since I'm the OP that's what I am going to do.
Did you put in an insurance claim for the new dash frame ?
Re: Changing VIN plate to new dash frame [Re: JohnRR] #1520238
10/24/13 12:00 AM
10/24/13 12:00 AM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Yes I did.
2020 RAM Longhorn 4x4
2022 Jeep Grand Cherokee Overland
Re: Changing VIN plate to new dash frame [Re: 7812845] #3184904
10/18/23 06:32 PM
10/18/23 06:32 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The price of rosette rivets has crashed. Used to be $60 for a pair. Now $2.29 a pair plus $1.57 postage from China here.
You'll need to color them black though, since they are stainless. These are 1/8" diameter, but be careful - the $9.99 ones from Amazon are 1/4" here. However, they say these are "NOS Dash Rosette Rivets Stainless Steel Fit for Ford Amc Chrysle Door Tag" with Chrysler misspelled. Not NOS. Also not black. Also won't fit dash, unless the drawing is incorrect and it's the head that's 1/4" and not the shaft.
But really, you can just make your own for free with a file in a few minutes if you don't have the factory originals. Factory original blackened aluminum rivet without the pulled steel shaft above, two home made ones below, also aluminum, blackened with magic marker, and the steel shaft. I'll be gluing the factory original heads and shafts back on my newly painted dash. Made the copies just for fun.
Re: Changing VIN plate to new dash frame [Re: Rhinodart] #3184925
10/18/23 08:38 PM
10/18/23 08:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Rhinodart
Quote
The "el cheapo" way to get around the rivet prices is to remove the tag by grinding off the rivet butts under the dash, then gently punch out the rivets still attached to the tag.
Use a thin layer of epoxy to attach the tag/rivet heads to the new dash.
Now you did it, we have been trying to keep that secret for decades... <img src="/ubbthreads/images/graemlins/tsk.gif" alt="" /> <img src="/ubbthreads/images/graemlins/biggrin.gif" alt="" />
And I thought I was the only one who thought of that.
Re: Changing VIN plate to new dash frame [Re: cudaman1969] #3184968
10/19/23 01:49 AM
10/19/23 01:49 AM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Quote
BE SURE to put a piece of tape across the rivets and tag; if you don't, you'll be looking all over for two very small rivet heads.
Re: Changing VIN plate to new dash frame [Re: Jer] #3185074
10/19/23 02:42 PM
10/19/23 02:42 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
BTDT!
On a pea gravel textured patio slab.
Page 3 of 3 1 2 3
