LIfted trucks running an NP208 - drive line angle? #1519833
10/18/13 11:32 PM
10/18/13 11:32 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I am not really sure where to begin here so please bare with me.
I have a short box W150 with a Dana 60 swap in the rear and GM 8-lug/disc brake knuckle swap on the D44 up front. It has a 4" all spring tough county lift and 33x11.50 tires. So far I have blown up two constant velocity joints in the front drive line. The last time it happened the drive shaft took out the passenger side exhaust and almost stranded us in BFE on in a remote canyon between two mountains. After this experience I have decided that CV joints are unreliable. \
I never really gave much thought to the why's of Dodge using the CV joint in the front drive line until I started considering that the t-case yoke angle had to point up in in order for the rest of the engine/trans/t-case to be down tilted for the rear drive line. Do I have a chance in hell of making this work without a CV joint or swapping in a 203 t-case? It looks like if I shim the t-case mount to get the front yoke angle level or the rear output from the t-case will also be level. FWIW from the factory it measures 3 deg positive vs the +2 deg on the front diff yoke. I am kind of stumped here. Am I missing something when it comes to making the CV joint last in this application?
Sorry for the likely confusing, long post but I am kind of at a loss here.
Re: LIfted trucks running an NP208 - drive line angle? [Re: Jeremiah] #1519834
10/18/13 11:49 PM
10/18/13 11:49 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I have an 80' W-150 shortbox with a 208 with a 6" super lift and I had to clearance the CV in some areas to prevent it from coming in contact which prolly would have exploded otherwise
Re: LIfted trucks running an NP208 - drive line angle? [Re: 500ciDuster] #1519835
10/19/13 12:07 AM
10/19/13 12:07 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
You should not have any problem with the driveshaft with a 4" lift. Either the ujoints were wore out, or like said, some areas need clearanced when the angle gets steeper.
I have ran much more lift than that without trouble. A 203 transfer case also uses a cv, so you won't gain anything there.
If you are out in bfe, it is always a good idea to carry extra ujoints, and or even an extra driveline.
Re: LIfted trucks running an NP208 - drive line angle? [Re: 500ciDuster] #1519836
10/19/13 12:14 AM
10/19/13 12:14 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Pretty sure superior is 5" but yes the clearancing is needed sometimes. 4" lifts hardly have any issues
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519837
10/19/13 12:18 AM
10/19/13 12:18 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Can the pinion shims be used on the front axles, or will that cause issues with alignment?
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519838
10/19/13 12:18 AM
10/19/13 12:18 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Believe 65-93 all use the same style front just hehe odd units ds is longer and D60 front setups are shorter than 44s
Re: LIfted trucks running an NP208 - drive line angle? [Re: hp383] #1519839
10/19/13 12:23 AM
10/19/13 12:23 AM
V
viperblue72 Offline
viperblue72  Offline
V
I had a 5.5 superlift that came with the shims on the springs. DO NOT USE THEM.
If you have ever tried to drive a car fast in reverse, your truck will feel like that driving forward. It compromises your steering big time. Your truck will pull all over the place and you will be fighting the steering wheel. I put 35" boggers on at the same time and always blamed those. But once I got rid of those, the problem remained. I pulled the shims off and my steering was perfect again.
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519840
10/19/13 01:04 AM
10/19/13 01:04 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
It will steer like a shopping cart.
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519841
10/19/13 01:07 AM
10/19/13 01:07 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
The divorced transfer case (203/205) does not use a CV because the angle of the t-case is not affected by the installed angle of the engine/trans, hence my issue with this truck utilizing the stupid married 208 chain driven POS t-case.
The problem I am having with the setup is the centering ball/spring and cup gets torn up. I guess I must be going something wrong. It would be nice to be able to drive 55-60 on the snow packed highways in 4wd this winter.
Re: LIfted trucks running an NP208 - drive line angle? [Re: Jeremiah] #1519842
10/19/13 10:30 AM
10/19/13 10:30 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yeah that's suppose to be 75-93 but my big fingers and little buttons on my phone
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519843
10/19/13 10:44 AM
10/19/13 10:44 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Clearance the cv setup. If that don't work or isn't your real problem Id upgrade to a 205.
Re: LIfted trucks running an NP208 - drive line angle? [Re: hp383] #1519844
10/19/13 10:52 AM
10/19/13 10:52 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You don't want room mess with the front axles opinion rotation as it will cause worse issues with steering
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519845
10/21/13 04:42 PM
10/21/13 04:42 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
Your 208 is not the problem. The problem is front drive shaft angle. The C/V joints job is to lessen the the angle of front output flange, the 2 degrees up you referred to. Each u joint in the C/V halves the drive shaft upper angle. The problem is the small u joints and that the manufacturer of those C/V s never intended it to deal with the lift / angle. The best way to take care of this problem is buy a high angle c/V joint. Problem gone or you can spend money on all kinds of things that will not take care of the problem. Tom woods, high angle drive shaft or others. You must get one rated for more angelarity.
Re: LIfted trucks running an NP208 - drive line angle? [Re: 76dodgeboy] #1519846
10/23/13 02:46 AM
10/23/13 02:46 AM
V
viperblue72 Offline
viperblue72  Offline
V
I think you are correct about the 75-93. I put a 1973 d44 in my 1978 and the front pinion angles downward a lot more than the later d44.
