Re: Part#6013 Hemi 6 ignition controller?
[Re: bee71mopar]
#1519811
10/19/13 01:50 PM
10/19/13 01:50 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Last I talked to Josh at HHP he said the best coils to use is the stock coils...he tosses those MSD ones.
Just getting the controller and harness no coils. Tbd for the heads up. Matt
[Re: MattW]
#1519812
10/19/13 01:57 PM
10/19/13 01:57 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
Thanks STEFF. I'be searched about 50 posts and came up with nothing specific. Your old engine I believe was a 6.1. So the 6013 controller and the harness for coil on plug :not the plug wires that cross over the intake, are good? Matt.
Yes, I use the 6.1 coils. If you go to the MSD site, you can download the instructions for the 6013 and it clearly shows the 2 harness options in it I think you can use it on the other coils as well with the right harness. You buy the harness seperately from the 6013..
[Re: STEFF]
#1519813
10/19/13 02:02 PM
10/19/13 02:02 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
The 3rd Gen coils we offer are only for extreme cylinder pressures. Steff has the 2nd Gen, good until around 12lbs of boost. Being able to adjust the dwell is a must to bee able to use our "Uber" coils. AJ at Arrington know all about them, as he is using them on his car.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: Moparmal]
#1519819
10/22/13 05:54 PM
10/22/13 05:54 PM
Posts: 3,943 Melbourne.....Oz-land
Moparmal
Your welcome Be aware that my sensors were from a 6.1 crate motor and weren't compatible with the later MSD harness.... Earlier 6.1s may not have this issue. I can guarantee that sensor compatibility will be you only problem. Maybe I should get a green card and work for MSD !
[Re: Moparmal]
#1519820
10/22/13 07:00 PM
10/22/13 07:00 PM
MattW
Ontario Canada
Your welcome
So will a 5.7 sensor fit the 6.1 block? Or do I cut the harness and graph the 6.1 plug on it?
What ever you do DON'T leave your country. You guys have your sh$t together.
[Re: MattW]
#1519821
10/22/13 10:43 PM
10/22/13 10:43 PM
Moparmal
Yes, the later 5.7 cam and crank sensors are a direct plug and play into the 6.1 block. I posted the part #s on my blog which is that first link I put up. FWIW most of what I know I learned from guys on other forums ...... Ive found most parts suppliers like TTI and MSD have been useless - even Bob Mazzolini was more help!
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
