Re: engine support for changing transmission
[Re: OldMoparMan]
#1519745
10/18/13 08:42 PM
10/18/13 08:42 PM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Bottle jack and a 2 X 6 under the rear of the pan allows you to move it up and down as needed for fitting, reinstall, etc.
Old, tired, and sometimes broke down. Me, not my car...
[Re: slantzilla]
#1519748
10/19/13 08:59 AM
10/19/13 08:59 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
while attaching the trans to the engine, I like letting the engine hang down in the back, because it gives more room around the top of the bell up in the trans tunnel to work with while attaching the hardware. once it's bolted together, I like to use a floor jack on the trans to lift it up into position while working the trans cross member into place.
**Photobucket sucks**
[Re: 70Cuda383]
#1519749
10/23/13 03:01 PM
10/23/13 03:01 PM
An engine hoist works well. Small block heads have unused bolt holes on the firewall side that are great attachment point. The same holes that would be used for the neg bat cable and alt bracket. The downsides are the hoist legs in yer way under the car and the hydrolic bottle bleeding down a bit over night.
I prefer using wood blocks under the oil pan. A scrap bit of 6x6 and shims as needed. Unbolt the trans mount, lift the tail a bit to lift the back of the block. Get the post in there then let it down and unbolt. The opportunity for cursing is when the trans jack and the support post want to occupy the same bit of garage floor.
Tranny shops use a gizmo that is basicly a bit of squre tube under the pan and adjustable j-hooks for grabbing the frame somewhere. Have seen harbor frieght / norhern tool variants.
