Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Borgeson Stering Box [Re: Dan@Hotchkis] #1519618
03/20/14 02:49 PM
03/20/14 02:49 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
Curious, installed the box today. Rotated the box to find center (almost 4 turns) I was wondering about half way, you can feel some resistance (for about half a turn) then its easy peasy again. Is this normal? Mind you this is just the steering column hooked up to the box. I haven't installed the pitman arm or any ps hoses.
Re: Borgeson Stering Box [Re: dangina] #1519619
03/21/14 04:28 PM
03/21/14 04:28 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Perfectly normal. The "high spot" is tight. When centered the flat faces the driver side frame rail.
Re: Borgeson Stering Box [Re: BergmanAutoCraft] #1519620
03/21/14 11:11 PM
03/21/14 11:11 PM
dangina Offline
dangina  Offline
great thanks! your coupler is the cats meow
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519621
03/26/14 07:41 PM
03/26/14 07:41 PM
dangina Offline
dangina  Offline
Question about reinstallng the pitman arm on this box, I put on the arm, only half the threads on the arm are engaged, I tightened the nut on first to get more engagement but when I take it off and put the lock nut and nut back on im just barly flush with the bottom of the steering box shaft. Is this normal?
Re: Borgeson Stering Box [Re: dangina] #1519622
03/26/14 08:25 PM
03/26/14 08:25 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think I might have been a tad past flush. I used my original arm too. It will only go so far before the torque spec is met.
Mopar to the bone!!!
Re: Borgeson Stering Box [Re: 72Swinger] #1519623
03/26/14 09:20 PM
03/26/14 09:20 PM
dangina Offline
dangina  Offline
using the fast ratio arm I guess as long as I get my 175lbs of torque? Right now its not quite flush. I need a bigger torque wrench...
Re: Borgeson Stering Box [Re: dangina] #1519624
03/26/14 09:39 PM
03/26/14 09:39 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Got any pictures? The position of that arm affects bumpsteer.
Re: Borgeson Stering Box [Re: brads70] #1519625
03/26/14 10:42 PM
03/26/14 10:42 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I agree that it could if it was way out of whack. There really isnt a remedy to press that arm on any further short of hydraulic press and possibly splitting it. He has an aftermarket arm and the tolerances may be Chinese. I will go out and take a pic of mine.
Re: Borgeson Stering Box [Re: brads70] #1519626
03/27/14 02:01 AM
03/27/14 02:01 AM
dangina Offline
dangina  Offline
I'll take a pic, I tried centering the wheels and the ps box before i put on the pitman arm. how does it affect bumpsteer?
Re: Borgeson Stering Box [Re: dangina] #1519627
03/27/14 06:48 AM
03/27/14 06:48 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
If not seated properly it could cause the centerlink to be out of parallel with the car, causing uneven linkage motion.
I've got one or 2 threads showing.
Re: Borgeson Stering Box [Re: 1fastabody] #1519628
03/28/14 12:42 AM
03/28/14 12:42 AM
dangina Offline
dangina  Offline
took a quick pic - I pulled it off, repositioned it and put it on 3 times and got the same results every time so screw it, I got my 175lbs of torque on it, its not going anywhere
Re: Borgeson Stering Box [Re: dangina] #1519629
03/28/14 04:13 AM
03/28/14 04:13 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm not liking the difference between these two pictures both with Borgeson Boxes.
I know of another Borgeson that the installer said it put the pitman in a different place and the centrelink was not parallel. I thought it was an anomaly with that car or pitman, but what dangina has posted has me wondering what is going on.
Re: Borgeson Stering Box [Re: autoxcuda] #1519630
03/28/14 05:04 AM
03/28/14 05:04 AM
dangina Offline
dangina  Offline
The fast ratio arm has no center link like the old pitman had. I can't remember who the other poster on here said they were gonna run a fast ratio on their boregson, I wondered how his turned out?
Re: Borgeson Stering Box [Re: dangina] #1519631
03/28/14 05:53 AM
03/28/14 05:53 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I meant this being the centerlink:
Re: Borgeson Stering Box [Re: autoxcuda] #1519632
03/28/14 06:17 AM
03/28/14 06:17 AM
The Netherlands
The Netherlands
For everyone's info, I have a small sector Borg-Box and used (I recall) a '72 manual steering pitman.
This might explain the difference in the nut's thread-engagement.
Re: Borgeson Stering Box [Re: dangina] #1519633
03/28/14 09:32 AM
03/28/14 09:32 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Are you referring to the master spline in the arm? I'm not liking the looks of that either? Does the center link sit parallel and flat in both axis? It appears the splines are not cut deep enough on the shaft in the steering box? Looks like they got it right on the small sector shaft box but the large one needs a little "tweaking" ? Fast ratio or standard, small or large sector shaft, they should both sit in the same position on the steering box.
Re: Borgeson Stering Box [Re: brads70] #1519634
03/28/14 10:32 AM
03/28/14 10:32 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would question the aftermarket pitman arm before throwing the box under the bus.
Re: Borgeson Stering Box [Re: 72Swinger] #1519635
03/28/14 10:42 AM
03/28/14 10:42 AM
Wildwood, FL
1fastabody Offline OP
Wildwood, FL
Do you have the old pitman arm or another pitman arm that you can try? This would take the pitman arm out of the question. I know a lot of these replacement parts are machined over seas and the quality control is not that great.
Re: Borgeson Stering Box [Re: 72Swinger] #1519636
03/28/14 10:45 AM
03/28/14 10:45 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Good point I assumed he just replaced the box with an existing set up.
Re: Borgeson Stering Box [Re: brads70] #1519637
03/28/14 02:03 PM
03/28/14 02:03 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I agree. And Dangina is using a Quick Ratio pitman arm that is a low volume speciality item, not a bread and butter pitman that fits 1/4 million cars like the regular ratio one. But I would like to figure what is going on because this is the second time I've heard of this from someone using the box.
I believe what determines the up and down position of the pitman is the taper in the splines. There is not a definitive land/shelf than the pitman hits. It's just the interference between the straight splines in the pitman against he taper of the splines at the end of the steering sector shaft.
IMHO, it's a machining feature that is a little tough to check.
