Re: Borgeson Stering Box
[Re: dangina]
#1519622
03/26/14 08:25 PM
03/26/14 08:25 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think I might have been a tad past flush. I used my original arm too. It will only go so far before the torque spec is met.
Mopar to the bone!!!
[Re: 72Swinger]
#1519623
03/26/14 09:20 PM
03/26/14 09:20 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
using the fast ratio arm I guess as long as I get my 175lbs of torque? Right now its not quite flush. I need a bigger torque wrench...
[Re: dangina]
#1519624
03/26/14 09:39 PM
03/26/14 09:39 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Got any pictures? The position of that arm affects bumpsteer.
[Re: brads70]
#1519626
03/27/14 02:01 AM
03/27/14 02:01 AM
dangina
I'll take a pic, I tried centering the wheels and the ps box before i put on the pitman arm. how does it affect bumpsteer?
[Re: dangina]
#1519629
03/28/14 04:13 AM
03/28/14 04:13 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
took a quick pic - I pulled it off, repositioned it and put it on 3 times and got the same results every time so screw it, I got my 175lbs of torque on it, its not going anywhere
I'm not liking the difference between these two pictures both with Borgeson Boxes.
I know of another Borgeson that the installer said it put the pitman in a different place and the centrelink was not parallel. I thought it was an anomaly with that car or pitman, but what dangina has posted has me wondering what is going on.
[Re: autoxcuda]
#1519630
03/28/14 05:04 AM
03/28/14 05:04 AM
dangina
The fast ratio arm has no center link like the old pitman had. I can't remember who the other poster on here said they were gonna run a fast ratio on their boregson, I wondered how his turned out?
[Re: dangina]
#1519631
03/28/14 05:53 AM
03/28/14 05:53 AM
autoxcuda
So Cal
I meant this being the centerlink:
[Re: brads70]
#1519634
03/28/14 10:32 AM
03/28/14 10:32 AM
72Swinger
Nebraska
I would question the aftermarket pitman arm before throwing the box under the bus.
[Re: 72Swinger]
#1519636
03/28/14 10:45 AM
03/28/14 10:45 AM
brads70
Ontario,Canada
Good point I assumed he just replaced the box with an existing set up.
