Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: Borgeson Stering Box [Re: komninon] #1519598
02/20/14 05:59 PM
02/20/14 05:59 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
i will be using the stock pitman arm with the new box. c
Bummer....
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519599
02/20/14 08:33 PM
02/20/14 08:33 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I'm also interested to hear about the Borg'sn box WITH the fast-ratio longer arms (pitman and idler).... for steering response.
I initially also suspect the inside front tires will hit the frame rail more easily.
Aside from the newer technology of the Borg'sn box, in my opinion, the biggest advantage is the lighter weight of it as compared to a factory older ps box.... continuos reduced weight = faster lap times in every respect (accel, decel, cornering).
I'm putting Fast-Ratio on my 67 Valiant with a welded K-frame and a Borgeson. Parts just arrived, should be up and driving in 3 weeks...
Re: Borgeson Stering Box [Re: Tomswheels] #1519600
02/20/14 10:09 PM
02/20/14 10:09 PM
Washington State
cudaragtop Offline
cudaragtop  Offline
Washington State
Sweet!
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519601
02/20/14 11:30 PM
02/20/14 11:30 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
As a learning moment for me....why would this be?
Fast ratio arm(s) on a FF box or Borg. box....wouldn't the physical travel of the arm(s) through space be the same (assuming the Borg. box pitman shaft exits the box at the same point in space as the factory / FF box)? You might get there (the frame rails/end of travel) quicker/sooner with the Borg. box due to a faster internal ratio, but wouldn't ultimate travel be the same?
We're getting dangerously close to the limits of my thinking here...
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Borgeson Stering Box [Re: DynoDave] #1519602
02/21/14 01:53 AM
02/21/14 01:53 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Longer arms=more movement per steering wheel rotation=more movement at the tire per steering wheel rotation.
Mopar to the bone!!!
Re: Borgeson Stering Box [Re: DynoDave] #1519603
02/21/14 03:45 AM
02/21/14 03:45 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Longer arms mean quicker response and more total throw for the same amount of rotation.
Damon
Re: Borgeson Stering Box [Re: mopardamo] #1519604
02/21/14 04:04 AM
02/21/14 04:04 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
You guys are saying the same thing with different words.
Re: Borgeson Stering Box [Re: Tomswheels] #1519605
02/21/14 04:56 AM
02/21/14 04:56 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
interested in this I've heard that it would be too twitchy on the hiway with this setup, but no actual real proof. I bought the stock pitman and idler but did the firm feel roller bearing idler kit instead but I haven't installed them yet, I may just bite the bullet and get the fast ratio arms instead. I figure that it should give a ratio around 2 turns lock to lock? which shouldn't be that bad - I've read that the camaro and firebird guys are getting 1.7 turns lock to lock and they don't seem to have any problems, actually they comment about getting that ratio lower...
Re: Borgeson Stering Box [Re: dangina] #1519606
02/21/14 07:23 AM
02/21/14 07:23 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I got the fast ratio arms, sector support kit with the FF stage 2 box and it all feels really good!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Borgeson Stering Box [Re: dangina] #1519607
02/21/14 06:21 PM
02/21/14 06:21 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Dangina -- the "twichyness" will be caused by the alignmemt... if not enough positive caster, then more twitchyness.... Toe out will also welcome it, but IMO... just adapt and re-learn the car's new steering. My steering is quickened, additionally, by a smaller diameter steering wheel (11.5" dia)... driving on the hwy or road courses are no problem.... very enjoyable!... I have no "twitchyness" whatsoever.... steering is very responsive (original never rebuilt T/A ps box, fast rati pitman arm, corrected longer length idler arm).
Another point to consider, is lower/wider profile tires ~50-45-40-35 having their wider/narrower contact patch, vs taller narrower profile tires ~55-60-65-70 having their narrower/longer contact patch. Latitude (cornering) improvemenmts benefit from wide/narrow patches (ie: auto-x/road racer tires), while longitudinal (accel/decel) improvements benefit from narrower/longer patches (ie: dragster rear tires). Steering with a narrower/longer contact patch (55-60-65-70 profiles) carry the car further straight; opposite with lower proflie tires.
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519608
02/21/14 07:20 PM
02/21/14 07:20 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Tom's Borgeson Box showed up today. Once his stuff comes back from powdercoat, It will be going in.
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519609
02/21/14 07:46 PM
02/21/14 07:46 PM
dangina Offline
dangina  Offline
Thanks mitch for the insight, you just made my decision easier ordered a set today. Worse case scenario if it seems like too much, I put the stock ones back in
*edit* talked to matt at firm feel, says I can use their idler bearing roller kit with this setup, best of both worlds
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519610
02/23/14 06:01 PM
02/23/14 06:01 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I still have a stock, unmodified K-member in my '73 Dart.
Since the K-member in my car has been powdercoated at one time, adding reinforcements while mounted in the car is a bit hard to do at the moment.
I do want to gusset the steeringbox mount but that will probably be when I'm ready to an engine swap in the car.
Just out of the blue I decided to add a simple plate to gusset and reinforce the steeringbox-mount a little better.
I made the plate large enough to reach the areas where I could still easily clean the powder coating off the member with an angle grinder.
I also welded a plate across the bottoms of the LCA's and welded the tierod sleeves in the centers.
When I took the car for a spin after this I tought I could feel the steering felt a bit tighter and more direct. But the improvement was much yet.
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519611
02/27/14 09:17 PM
02/27/14 09:17 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I just ordered a borgeson box and qa1 kmember along with qa1 LCA's... wondering if I will have to clearance the box for the qa1 kmember?
Re: Borgeson Stering Box [Re: Pool Fixer] #1519612
02/27/14 11:22 PM
02/27/14 11:22 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Where from?
Re: Borgeson Stering Box [Re: BergmanAutoCraft] #1519613
02/28/14 12:16 AM
02/28/14 12:16 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Summit
Re: Borgeson Stering Box [Re: Pool Fixer] #1519614
02/28/14 06:54 AM
02/28/14 06:54 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
mine fit good no grindage
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Borgeson Stering Box [Re: sublimehemi] #1519615
02/28/14 10:34 AM
02/28/14 10:34 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Thanks! another question: I installed the SD concepts serpentine conversion on my 440 so I'm running a 99 grand cherokee power steering pump. Not sure what hoses/fittings I'll need.
Re: Borgeson Stering Box [Re: Tomswheels] #1519616
03/19/14 03:56 AM
03/19/14 03:56 AM
Washington State
cudaragtop Offline
cudaragtop  Offline
Washington State
Just checking to see if you got it installed yet...
Re: Borgeson Stering Box [Re: cudaragtop] #1519617
03/19/14 11:57 AM
03/19/14 11:57 AM
Nope. We are still waiting for some other parts to come in.
