Page 1 of 9 1 2 3 4 5 6 7 8 9
Borgeson Stering Box #1519518
10/18/13 03:35 PM
10/18/13 03:35 PM
Wildwood, FL
1fastabody Offline OP
Wildwood, FL
I found this post on another forum and thought this pic really shows the size difference well.
Here is the original post:
http://www.forbbodiesonly.com/moparforum...-this-afternoon
Stock vs. Borgeson
Re: Borgeson Stering Box [Re: 1fastabody] #1519519
10/18/13 04:09 PM
10/18/13 04:09 PM
Georgia
72440CUDA Offline
72440CUDA  Offline
Georgia
Cool, thanks. I was set to get a Firm Feel stage 2 box, but it think my decision has swayed to the Borgeson. I have a big block with Hooker Super Comp headers. With this set up, I would never be able to get a fast ratio pitman/idler arm, along with a header tube is kissing my power steering box . From what it sounds like, this would take care of the interference with the header, take care of my sloppy steering and give it a bit faster ratio.
Re: Borgeson Stering Box [Re: 72440CUDA] #1519520
10/18/13 04:44 PM
10/18/13 04:44 PM
Wildwood, FL
Wildwood, FL
Yea I was planning on getting the Borgeson Box, but never knew that there was that much size difference. That pic shows it well. Glad I was able to help.
Re: Borgeson Stering Box [Re: 1fastabody] #1519521
10/18/13 11:29 PM
10/18/13 11:29 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I've sold a lot of my kits now, and the feedback is always the same - people didn't realize how good the steering can be.
Re: Borgeson Stering Box [Re: BergmanAutoCraft] #1519522
10/21/13 10:20 AM
10/21/13 10:20 AM
indy
70moparmike Offline
70moparmike  Offline
indy
can you use the fast ratio idler and pitman arm with tti headers? 69 b/b b body? thanks
Re: Borgeson Stering Box [Re: 70moparmike] #1519523
10/22/13 12:58 PM
10/22/13 12:58 PM
Long Island, NY USA
Long Island, NY USA
You could if you have the header clearance. However, I have not tried it.
Re: Borgeson Stering Box [Re: 70moparmike] #1519524
10/22/13 01:05 PM
10/22/13 01:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The pitman and idler should be in the same place as with a factory box. So if it worked with a factory box, it should in theory work with the Borgeson.
Caution: That would give you somewhere very roughly in the range of 10:1 to 11:1 steering ratio with the 14:1 Borgeson box. Be prepared for that.
Re: Borgeson Stering Box [Re: autoxcuda] #1519525
10/22/13 01:44 PM
10/22/13 01:44 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've been driving daily with a Borgeson box for a couple of months now in my Dart and I don't think I would mind some more direct steering than the 14:1 I now have.
Re: Borgeson Stering Box [Re: autoxcuda] #1519526
10/22/13 11:09 PM
10/22/13 11:09 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
10 OR 11 TO 1 RATIO WOULD BE AWESOME!!! GO FOR IT!!! THAT'S WHAT WE WANT.. FASTEST STEERING POSSIBLE!!!
Re: Borgeson Stering Box [Re: BigBlockMopar] #1519527
10/23/13 01:24 AM
10/23/13 01:24 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What size is your steering wheel? If fast ratio arms will fit my car with a Gen III and headers I would try them at least. Right now with a 14" wheel and the Borgeson I am totally happy as I can steer and shift smoothly without loss of control. I havent found myself TOO busy at all. Autox brings a whole different set of "needs" to the table I expect.
Mopar to the bone!!!
Re: Borgeson Stering Box [Re: autoxcuda] #1519528
10/23/13 11:02 AM
10/23/13 11:02 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You mean needing to install a Semi steering wheel, or going all out and adding an 8" ski boat steering wheel?
Re: Borgeson Stering Box [Re: jcc] #1519529
10/23/13 12:04 PM
10/23/13 12:04 PM
Long Island, NY USA
Long Island, NY USA
I'm working on a tuff wheel look alike with a THICK leather grip and 13..75" diameter. It should help the "feel" somewhat.
Re: Borgeson Stering Box [Re: Mopar Mitch] #1519530
10/23/13 10:48 PM
10/23/13 10:48 PM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I wondered about this - is this too much for daily driving? I have the borgeson box and both stock and fast ratio pitman and idler arms at my disposal
Re: Borgeson Stering Box [Re: dangina] #1519531
10/24/13 01:56 AM
10/24/13 01:56 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Perfect if you have a way to set toe adjustment at home. Now you can check both ratios to what YOU LIKE. Ratio is mostly driver preference within a range. In an autocross though, very quick is almost always what drivers want.
I'd accurately measure each tie rod now to the 16th/32nd of inch and count threads exposed and check toe with plate or tread edge. Then put the fast ratio stuff on. Then reset toe only with tape measures and plates/edge.
If you want to go back, go back to your tie rod measurements, thread counts, and total toe measurements.
Get a ride height measurement at current and each total toe measurement. Measure and adjust each time on same location on the floor. Marking it with some tape on the floor is handy.
Re: Borgeson Stering Box [Re: autoxcuda] #1519532
10/24/13 02:55 AM
10/24/13 02:55 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
How much lighter is the Borgeson over the factory unit ?
Re: Borgeson Stering Box [Re: PHJ426] #1519533
10/24/13 04:02 AM
10/24/13 04:02 AM
The Netherlands, OV
dickdale Offline
dickdale  Offline
The Netherlands, OV
Borgeson weighs 22 pounds... Stock, anyone?
Re: Borgeson Stering Box [Re: dickdale] #1519534
10/24/13 04:44 AM
10/24/13 04:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The stock one has to weigh in around 40 lbs !
Re: Borgeson Stering Box [Re: autoxcuda] #1519535
10/24/13 08:08 AM
10/24/13 08:08 AM
dangina Offline
dangina  Offline
whats a good starting point when you put all of your front suspension together? I have a castor/camber guage as well as a bump steer guage. I think I understand your description on toe, Do you check toe with the weight on the ground or when the spindle is at the top (like simulating the same as you do for bump steer?
Also on you tie rods, what lengths do you start your tie rods at?
Re: Borgeson Stering Box [Re: dickdale] #1519536
10/24/13 09:07 AM
10/24/13 09:07 AM
Wildwood, FL
Wildwood, FL
I read somewhere that they weighed 37 lbs.(stock) I don't have one to weigh but I think that is close.
Re: Borgeson Stering Box [Re: 1fastabody] #1519537
10/24/13 09:12 AM
10/24/13 09:12 AM
Wildwood, FL
Wildwood, FL
Bergman,
Maybe you can chime in on this, Is there any advantage to going to the larger pitman shaft box?
