GIVE UP T&D #1519444
10/18/13 01:32 PM
10/18/13 01:32 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
well i now give up, broke another T&D rocker, i am at my wits end, each time right at 2/3 shift, last time i dropped shift rpm from 7000 to 6800 hoping to help, about 10/12 rockers last five years, maybe 30/50 runs on replacements, ex/int any clyinder does not matter, i guess i need to have a "expert" look at my valve train
540 cu stage IV heads .660 roller
on the good side went 8.92 151mph before 1st round and got my entry fee back
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: GIVE UP T&D [Re: 440lebaron] #1519445
10/18/13 01:52 PM
10/18/13 01:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Something`s going into bind and or clearance issues come to mind. Valve float maybe? Not set up correctly?
Re: GIVE UP T&D [Re: 440lebaron] #1519446
10/18/13 01:55 PM
10/18/13 01:55 PM
USA
B3RE Offline
B3RE  Offline
USA
To tear up rockers like that you have to have valvetrain issues. PM me if you want it diagnosed.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: GIVE UP T&D [Re: B3RE] #1519447
10/18/13 07:19 PM
10/18/13 07:19 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
T & D's here with sick spring pressure. .896 lift cam shift at 7200 rpms. no issues at all.5 years now.
Re: GIVE UP T&D [Re: 440lebaron] #1519448
10/18/13 07:27 PM
10/18/13 07:27 PM
When your breaking race parts there is usually a reason thier failing The hard part, sometimes, is figuring out why they broke Now get to work finding out why your breaking them How close are your valve springs to coil bind? How much seat and open pressures are you running now? Which type of T&D rockers are you using, single shafts or paired rockers per shaft? Lots of gremlins out there
Re: GIVE UP T&D [Re: Sammy] #1519449
10/18/13 07:30 PM
10/18/13 07:30 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have the single shaft T&D on my 440-1's. .830 lift 325lbs on the seat and boost on top of that. never had a failure driving it on the street or racing it. Something is wrong in your valve train.
are they hitting the retainer on the inside of the rocker? How much valve clearance? hows the geometry? coil bind? Valve float?
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: GIVE UP T&D [Re: bigtimeauto] #1519450
10/18/13 09:31 PM
10/18/13 09:31 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My T&D are used, how old???? .800"@7000 , no issues. Lash stays dead on. My buddy just rebodied his after aprox 700 passes. BB Chevy +1.00" cam lift@1000 psi open
Doug
Re: GIVE UP T&D [Re: dvw] #1519451
10/18/13 10:00 PM
10/18/13 10:00 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I broke one early this year. No telling how many runs they had on them as they came from a NASCAR team form the early 2000's. I had to buy seven used from Ritter because some were mismatched. One of the seven "Dyno time only" broke. LOL
Leon
Re: GIVE UP T&D [Re: Leon441] #1519452
10/18/13 10:17 PM
10/18/13 10:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not to sound redundant but you have issues that are breaking the rockers. spring surge, insufficient spring pressure, interference of some type. no way you should have that many failures. do you know what your spring pressures are, part number, retainers, spring rate, installed height, open coil clearance?
you need to fill in the blanks and post pics of the failed parts and their installation. unless it's something bizarre it shouldn't take an expert to figure it out, roller valve trains will not live with weak springs.
Re: GIVE UP T&D [Re: 440lebaron] #1519453
10/18/13 11:03 PM
10/18/13 11:03 PM
westerly, ri. usa
westerly, ri. usa
i have checked every thing 6/7 times, i know i must be missing something, 2/3 sets of springs 2 valve jobs, .663 comp cam (new) open 1.90 680 lbs closed 1.40 270 lbs 1.55 dia spring for clearance issues, no coil bind .100+ clearance custom pushrods adjuster screw right on t&d spec,lash .022/.024 always right on never loose or tight, season over now have all winter
have posted a few times
Re: GIVE UP T&D [Re: 440lebaron] #1519454
10/19/13 10:31 AM
10/19/13 10:31 AM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Curator at Adams County Speed Shop
Re: GIVE UP T&D [Re: 440lebaron] #1519455
10/19/13 10:50 AM
10/19/13 10:50 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Can you post a few pics of the breakage?
Re: GIVE UP T&D [Re: 340man4ever] #1519456
10/20/13 06:00 AM
10/20/13 06:00 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
.100 plus clearance may be the problem coil bind should be set off of net lift at between .060 and .100.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: GIVE UP T&D [Re: BIGSPEED] #1519457
10/20/13 10:58 AM
10/20/13 10:58 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I agree.I learned this the hard way. You have to use "all" the spring as stated above. All I did was changge installed height never broke another rocker. I bet if you look at the face of the valve stem that they will have x patterens or shiny all the way around. This evidence of valve float and the "jack hamer effect". When the valve stem and rocker tip crash together the stress on the rocker is multiplied. Like a hammer hitting steel.
