same head? #1519305
10/18/13 02:48 AM
10/18/13 02:48 AM
georgia
1340busa Offline OP
1340busa  Offline OP
georgia
hey guys does anyone know if the 5.2 magnum head is the same as the 5.9 magnum head?
Re: same head? [Re: 1340busa] #1519306
10/18/13 07:40 AM
10/18/13 07:40 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Yep
Re: same head? [Re: d-150] #1519307
10/18/13 01:02 PM
10/18/13 01:02 PM
yellow70charger Offline
5.9 r/t head if your looking for more go
Re: same head? [Re: 1340busa] #1519308
10/18/13 03:49 PM
10/18/13 03:49 PM
Look at the casting numbers If thier the same, they're the same
Re: same head? [Re: Cab_Burge] #1519309
10/19/13 09:36 AM
10/19/13 09:36 AM
Locomotion Offline
Locomotion  Offline
There are a couple of different castings of Magnum heads. But I'm not familiar with the years or applications. They can probably be used/mixed for street applications. But friends who race with them have said that there is one that flows a little better than the other.
Re: same head? [Re: Locomotion] #1519310
10/21/13 12:48 PM
10/21/13 12:48 PM
dogdays Offline
dogdays  Offline
To the OP: The difference in flow between all the heads is probably no more than the differrence between a factory valve job and a HP one. If one is racing a stock class, then the "natural" flow advantage of 2-3 cfm may be noticeable, since they are dealing in hundredths of a second ET.
R.
Re: same head? [Re: yellow70charger] #1519311
10/21/13 03:33 PM
10/21/13 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
All factory 5.2 and 5.9 magnum heads are the same for all intents and purposes, a couple different casting numbers but they all function close enough to the same that you can mix and match with no issues. A 5.9 R/T has the same exact heads as any other 5.9 of the same year.
