Leaking power steering pitman shaft seal #151914
11/16/08 08:11 PM
11/16/08 08:11 PM
NY
Beep Beep Offline OP
NY
Has anyone used Lucas power steering stop leak? My 69 RR pitman shaft seal leaks and I was thinking of using this Lucas product. I loose roughly 2 oz a year from the seal. Any advice.
Re: Leaking power steering pitman shaft seal [Re: Beep Beep] #151915
11/16/08 08:25 PM
11/16/08 08:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yes,.....I've used the Lucas power steering sealer,....it's about the only product Lucas makes that really works!.......small leaks, or seepage leaks,....anything else, best to replace or rebuild the unit in question
