Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing
[Re: domingo]
#151903
11/16/08 08:06 PM
11/16/08 08:06 PM
Posts: 25,988 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The Hemi uses a 172 tooth flywheel while the 383/440 uses the 143 tooth flywheel; different diameters.
Also the Hemi uses a didect drive starter while the 383/440 use the gear reduction starter; different mounting pad.
[Re: domingo]
#151905
11/16/08 08:16 PM
11/16/08 08:16 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
OK I see....the 172 tooth wheel and the starter I take they are HEMI only items....right?
And are they only available as original items or can you get aftermarket 172 tooth flywheels_?
I hear those direct drive starters are a pain in the butt and they are know to fail easily....right?
first one YES
Yes to AFTERMARKET
the DD starter is VERY hard to FIND and very $$$$ when and IF you find one , RobbMc sells a Replacement , but if you need to have an ORIGINAL PRY open the WALLET for the bell and the starter
[Re: domingo]
#151907
11/16/08 08:35 PM
11/16/08 08:35 PM
JohnRR
why did mopar have those HEMI scpecific items instead of using the regular B/RB for the HEMI as well?
Wasnt the B/RB stuff good enough???? Why not use the same stuff?
I believe in 70 and 71 they used the same bellhousings, flywheels (cept for the 8 bolts on the hemi) and starters for both HEMI and B/RB....right?
why did they do it ??? your guess is as good as mine , but that's the way it is so if you are after ORIGINALITY just realize it DOES NOT MATTER WHY , find the parts and buy them .
in 1970 someone decided it was CHEAPER to use the RB parts which gave the factory a HIGHER profit
[Re: 6PakBee]
#151909
11/16/08 08:54 PM
11/16/08 08:54 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
OK I see.... thanks for the replies.... even though my car is an original 69 matching numbers HEMI charger I dont see myself spending 3k on a correct housing, flywheel and starter that still need to be restored! I have a 69 2892626 bellhousing and I think the flywheel I got with the car is a billet 8 bolt 143 tooth unit. So that should work and look "STOCK".
[Re: domingo]
#151910
11/16/08 08:57 PM
11/16/08 08:57 PM
JohnRR
OK I see....
The only thing that will not look stock to the hemi purist will be the starter , but they will have to crawl under the car to see it .... use what you have .
[Re: domingo]
#151912
11/16/08 10:03 PM
11/16/08 10:03 PM
JohnRR
OK, that will work....
and if they crawl under the car to see if the starter is the correct direct drive unit I will have the chance to give em a good kick on the butt!
or the head ???
