2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing #151901
11/16/08 08:01 PM
11/16/08 08:01 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Whats the difference between the
2892257 11" clutch A-833 1968-1969 B-body 426 HEMI Cast Iron
and the
2892626 11" clutch A-833 1969 B-body C-body 383 440 Cast Iron
bellhousings?????
Why do they have different casting numbers of both use the 11" clutch???
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151902
11/16/08 08:04 PM
11/16/08 08:04 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
the difference is the the hemi starter and the hemi uses a 172 tooth wheel
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151903
11/16/08 08:06 PM
11/16/08 08:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Hemi uses a 172 tooth flywheel while the 383/440 uses the 143 tooth flywheel; different diameters.
Also the Hemi uses a didect drive starter while the 383/440 use the gear reduction starter; different mounting pad.
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: JohnRR] #151904
11/16/08 08:07 PM
11/16/08 08:07 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK I see....the 172 tooth wheel and the starter I take they are HEMI only items....right?
And are they only available as original items or can you get aftermarket 172 tooth flywheels_?
I hear those direct drive starters are a pain in the butt and they are know to fail easily....right?
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151905
11/16/08 08:16 PM
11/16/08 08:16 PM
JohnRR Offline
JohnRR  Offline
first one YES
Yes to AFTERMARKET
the DD starter is VERY hard to FIND and very $$$$ when and IF you find one , RobbMc sells a Replacement , but if you need to have an ORIGINAL PRY open the WALLET for the bell and the starter
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: JohnRR] #151906
11/16/08 08:26 PM
11/16/08 08:26 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
why did mopar have those HEMI scpecific items instead of using the regular B/RB for the HEMI as well?
Wasnt the B/RB stuff good enough???? Why not use the same stuff?
I believe in 70 and 71 they used the same bellhousings, flywheels (cept for the 8 bolts on the hemi) and starters for both HEMI and B/RB....right?
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151907
11/16/08 08:35 PM
11/16/08 08:35 PM
JohnRR Offline
JohnRR  Offline
why did they do it ??? your guess is as good as mine , but that's the way it is so if you are after ORIGINALITY just realize it DOES NOT MATTER WHY , find the parts and buy them .
in 1970 someone decided it was CHEAPER to use the RB parts which gave the factory a HIGHER profit
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151908
11/16/08 08:39 PM
11/16/08 08:39 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Who knows? Maybe they felt the 10 1/2" clutch wasn't enough with mid-60's technology and opted for the 11"/172 tooth/direct drive route. As a note, the automatics have always used gear reduction units so I would doubt it was a decision based on starter power. If you could find a 143 tooth aftermarket flywheel with an eight bolt pattern, that would be an option other than resorting to the '70-'71 aluminum bell.
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: 6PakBee] #151909
11/16/08 08:54 PM
11/16/08 08:54 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK I see....
thanks for the replies....
even though my car is an original 69 matching numbers HEMI charger I dont see myself spending 3k on a correct housing, flywheel and starter that still need to be restored!
I have a 69 2892626 bellhousing and I think the flywheel I got with the car is a billet 8 bolt 143 tooth unit. So that should work and look "STOCK".
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151910
11/16/08 08:57 PM
11/16/08 08:57 PM
JohnRR Offline
JohnRR  Offline
OK I see....
The only thing that will not look stock to the hemi purist will be the starter , but they will have to crawl under the car to see it .... use what you have .
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: JohnRR] #151911
11/16/08 09:56 PM
11/16/08 09:56 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
OK, that will work....
and if they crawl under the car to see if the starter is the correct direct drive unit I will have the chance to give em a good kick on the butt!
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: domingo] #151912
11/16/08 10:03 PM
11/16/08 10:03 PM
JohnRR Offline
JohnRR  Offline
or the head ???
Re: 2892259 HEMI bellhousing vs. 2892626 B/RB Bellhousing [Re: JohnRR] #151913
11/16/08 10:30 PM
11/16/08 10:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I like to keep the head for afterwards,,,when I run over it while I back up the car...LOL
