I need a wiring schematic for power windows on 82-93 #1518992
10/17/13 12:35 PM
10/17/13 12:35 PM
ME
79machocharger Offline OP
ME
I getting ready to pull the power windows mechanism out of a 89 or 90 dodge ram and was wondering if any one has a schematic for one so I can see where all the wires go. Hopefully there easy to get to under the dash I don't want to pull every thing out to get to where they connect. I'm kind of hoping they disconnect behind the kick panels and I can just make my own harness to make them work. I'm also taking out the power locks as well. I'm installing it all in my 78 ramcharger.
Thanks for any help.
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1518993
10/17/13 01:29 PM
10/17/13 01:29 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
All the PW/PDL harnesses I have pulled out Run the whole length of the dash, and plug in to the main harness around the top of the brake/gas pedals..
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1518994
10/17/13 02:41 PM
10/17/13 02:41 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I pulled all of the original wire harness out of my '86 Ramcharger SE including the entire dashboard to build the race truck. The only things that I saved were the brake light switch, the VIN tag (I will relocate it) and the bracket with the P-brake mechanism. Everything else was given to a fellow club member for his Ramcharger. I converted both doors to manual windows. This truck is never going back on the street or trail, race only.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: I need a wiring schematic for power windows on 82-93 [Re: RODHALL] #1518995
10/17/13 03:27 PM
10/17/13 03:27 PM
ME
ME
Do you guys think I'll be able to get the harness out without taking the dash out?
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1518996
10/17/13 06:10 PM
10/17/13 06:10 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
you will have to pull the vent duct work out.. It is difficult but not impossible.. is all you need the wiring?
Re: I need a wiring schematic for power windows on 82-93 [Re: RODHALL] #1518997
10/18/13 10:47 AM
10/18/13 10:47 AM
ME
ME
No I'm taking it all, regulators, motors, switches, and harness. He's selling it all to me for $100.00. I just need to take it all out.
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1518998
10/18/13 12:25 PM
10/18/13 12:25 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I put the whole setup in an 89 ramcharger years ago. did not take dash out, but I recall having to tilt it back a hair maybe to put the harness across the firewall. I installed the entire pw and pdl setup, and most impressive was the fact that the switches went in same location on door panel as the window cranks had been located. Spent 2 out of a 3 day mem day holiday getting it done.
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1518999
10/18/13 04:48 PM
10/18/13 04:48 PM
Bangor Me
Dodgeman55 Offline
Dodgeman55  Offline
Bangor Me
I have 1979,86,and 1990 D&W service manuals with wiring diagrams in them your welcome to come look at them.
1990 Rod Hall Truck #2
78 Lil Red Express
67 Coronet R/T
Re: I need a wiring schematic for power windows on 82-93 [Re: 79machocharger] #1519000
10/18/13 08:13 PM
10/18/13 08:13 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
your best bet is an 80...and they are tough to find. The later ones will be a little tougher to install.
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
