Hoosier Slick Date Code #1518497
10/16/13 06:08 PM
10/16/13 06:08 PM
Renton Washington
Triple Threat Offline OP
Renton Washington
Anyone know how to date code a Hoosier slick? Here is the only identifying mark I can find on it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Hoosier Slick Date Code [Re: Triple Threat] #1518498
10/16/13 11:30 PM
10/16/13 11:30 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If you call Hoosier post it on here so we know. Thx
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Hoosier Slick Date Code [Re: 1967dartgt] #1518499
10/17/13 12:01 AM
10/17/13 12:01 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
did you check both sides of the tire?
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Hoosier Slick Date Code [Re: StripeHOG] #1518500
10/17/13 03:04 AM
10/17/13 03:04 AM
Renton Washington
Renton Washington
Yes I checked both sides. I've searched high and low on the internet and can't find anything. Might give Hoosier a ring tomorrow.
-Dustin
Re: Hoosier Slick Date Code [Re: Triple Threat] #1518501
10/18/13 07:58 PM
10/18/13 07:58 PM
Renton Washington
Renton Washington
I emailed Hoosier about this, here was the response. I'm still waiting to hear back on how old mine are.
Dustin,
Every tire has a serial code embossed into the sidewall. On your tire it is on only one side about 1-2 inches up from the bead. It is a 4 character code. (Example: 5T6S or Y32Z). They are a bit difficult to read so be sure to record the proper sequence. When you have located it, just email Steve Hudspeth (shudspeth@hoosiertire.com) here at Hoosier. He can look up when the tire was produced using this 4-character code. He is also a drag racing product manager who should be able to answer your technical questions.
Thanks!
Kenneth R. Boyle
International Sales/Website Editor/SBU
-Dustin
