Suregrip .....Help Needed #1518405
10/16/13 02:34 PM
10/16/13 02:34 PM
DELAWARE
bee71mopar Offline OP
DELAWARE
Ok its a 8 3/4 pumpkin and on the passenger side the two inner splines do not line up so the axle can slide in all the way..granted I bought this rear used...how can I adjust it so they line up ???..
Any help is appreciative..
Re: Suregrip .....Help Needed [Re: bee71mopar] #1518406
10/16/13 03:02 PM
10/16/13 03:02 PM
Minn
SportF Offline
SportF  Offline
Minn
Stick an axle in the good side to keep it lined up, then partially stick in the other axle and turn it to line up. Although it may take as much as 100 ft pounds of torque to turn it (I think 110 is the factory rating for preload?) Good luck!
Re: Suregrip .....Help Needed [Re: SportF] #1518407
10/16/13 03:04 PM
10/16/13 03:04 PM
DELAWARE
DELAWARE
Thanks ill try it
Re: Suregrip .....Help Needed [Re: SportF] #1518408
10/16/13 03:13 PM
10/16/13 03:13 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
Doesn't the turning load go in inch pounds?
Pinion preload is in foot lbs and is a lot (110 or more), as mentioned.
Re: Suregrip .....Help Needed [Re: HairOtheDog] #1518409
10/16/13 03:19 PM
10/16/13 03:19 PM
DELAWARE
DELAWARE
So it looks like it will be a little easier if I reinstall the pumpkin in the rear axle housing..
Re: Suregrip .....Help Needed [Re: HairOtheDog] #1518410
10/16/13 03:56 PM
10/16/13 03:56 PM
Minn
SportF Offline
SportF  Offline
Minn
The 110 foot pounds is the "pre-load" on the suregrip. That is, with one axle stationary, it should take 110 foot pounds to turn the other. I have never seen a used one take that force, but I believe that is what it is. Keep in mind I believe, that is different than knowing exactly.
Re: Suregrip .....Help Needed [Re: HairOtheDog] #1518411
10/16/13 04:27 PM
10/16/13 04:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
inch pounds ?? One would be able to spin it by hand , if you can then the suregrip is spent .
Re: Suregrip .....Help Needed [Re: JohnRR] #1518412
10/16/13 04:53 PM
10/16/13 04:53 PM
KS.
HairOtheDog Offline
HairOtheDog  Offline
KS.
Sorry,
Let my Ford 9" rear info come out of its cage, it IS in inch pounds, but that's a ford 9".
Re: Suregrip .....Help Needed [Re: HairOtheDog] #1518413
10/17/13 02:54 PM
10/17/13 02:54 PM
DELAWARE
DELAWARE
Well can't get this thing to budge..
Re: Suregrip .....Help Needed [Re: bee71mopar] #1518414
10/17/13 04:13 PM
10/17/13 04:13 PM
Minn
SportF Offline
SportF  Offline
Minn
Try loosening the bolts that hold the case together, then try again. That will unload some of the spring force (assuming its a cone type). About the only way this gets out of whack is its put together the first time after re-assembly and an axle is not installed to line them up. Can you try to pry the axle/spyder gear to get it to line up? But put an axle in the lined up side other wise it will move too. Just don't exert enough force to knock a tooth off.
