Disc brake rubber bands? #151829
11/16/08 03:35 PM
11/16/08 03:35 PM
Toronto, Ont, Canada
boydsdodge Offline OP
I think this was recently asked but I can't find it after searching for a while.
But after years of using slider style disc brakes, should I be using the rubber bands that come with the calipers?
Why?
Seems like they would hold the caliper from sliding if I install them the way the service manual says.
Re: Disc brake rubber bands? [Re: boydsdodge] #151830
11/16/08 03:52 PM
11/16/08 03:52 PM
Me too. I bought a caliper the other day that has a pair of them(1st one ever) & I have no idea(yet) of where they go. If I hadn't read about them(on that prior thread) I would have thought that they got dropped in there by mistake when it was being boxed
Re: Disc brake rubber bands? [Re: RapidRobert] #151831
11/16/08 04:37 PM
11/16/08 04:37 PM
The service manual says that they slip over the machined way on the caliper adapter, then the caliper is to sit on or between. It doesn't say anything in the text just the pictures.
Re: Disc brake rubber bands? [Re: boydsdodge] #151832
11/16/08 04:42 PM
11/16/08 04:42 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Never knew where they went (til recently), never used them, never had a problem. Matter of fact, never seen then on a car I ever did brakes on either.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Disc brake rubber bands? [Re: 70dart360] #151833
11/16/08 05:12 PM
11/16/08 05:12 PM
o
wunderless Offline
wunderless  Offline
o
Holy crap! I just swapped over my brakes to disc's and had no idea what those were for!
I still don't understand how they fit but now I know they were supposed to serve some sort of purpose!
Thanks!
But existing is basically all I do.
Re: Disc brake rubber bands? [Re: wunderless] #151834
11/16/08 06:54 PM
11/16/08 06:54 PM
I think they are an anti rattle rubber.
Re: Disc brake rubber bands? [Re: boydsdodge] #151835
11/16/08 07:00 PM
11/16/08 07:00 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
BINGO... You are lucky winner... Pick a prize any prize?
Re: Disc brake rubber bands? [Re: 340dart4spd ] #151836
11/16/08 07:07 PM
11/16/08 07:07 PM
BDW Offline
BDW  Offline
They go on the slider adapter
Re: Disc brake rubber bands? [Re: BDW] #151837
11/16/08 07:24 PM
11/16/08 07:24 PM
now we know
