White Plugs Burning Lean?? #1518190
10/15/13 09:52 PM
10/15/13 09:52 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
Hi guys, I pulled my plugs and noticed that they are very white and not the typical brownish color. Here is my set up.
71 Dart/ LA360 with magnum heads, xe268 cam, air gap intake, street avenger 670 carb with factory jets.
Im wondering if its just a jetting issue that will take care of this or ??? Also will a engine that runs lean cause it to run hotter?
Re: White Plugs Burning Lean?? [Re: weazel] #1518191
10/15/13 10:23 PM
10/15/13 10:23 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
Yes and Yes
Re: White Plugs Burning Lean?? [Re: RBSat66] #1518192
10/15/13 10:26 PM
10/15/13 10:26 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
Ok, with out a A/F gauge how do you know what jets to put in? Is it trial and error? Do I try 1 size up or jump a couple sizes at a time?
Re: White Plugs Burning Lean?? [Re: weazel] #1518193
10/15/13 10:47 PM
10/15/13 10:47 PM
Post a picture of the spark plugs on here How many miles where on them when you looked at them? What heat range plugs and how much total timing are you running in the motor? Are you using the vacume advance? Last thing, do you know the true compression ratio? I like seeing my plugs clean, I do run a cold plug as lean as I can at part throttle cruise without pinging or detonation
Re: White Plugs Burning Lean?? [Re: weazel] #1518194
10/16/13 02:23 AM
10/16/13 02:23 AM
Unleaded gas does run cleaner but that's been around for decades. I'd jet up a bit & see how it acts. Might be a vac leak, might be too much timing, might be Ok as is. Without a meter I'd jet up & see what that does to the driveability (easy to do & easily reversible) & if it runs better stay with em
Re: White Plugs Burning Lean?? [Re: RapidRobert] #1518195
10/16/13 03:40 AM
10/16/13 03:40 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Is there any carbon built up on the threads? Where is the burn mark on the ground strap? Insulator color is pretty much meaningless anymore.
How is it running?
Re: White Plugs Burning Lean?? [Re: slantzilla] #1518196
10/16/13 04:01 AM
10/16/13 04:01 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The Street Avengers seem to be jetted very lean. My 770 Street Avenger on a stock 440 left the plugs very white out of the box as well.
Re: White Plugs Burning Lean?? [Re: weazel] #1518197
10/16/13 10:59 AM
10/16/13 10:59 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Jetting for WOT is the easiest. If you have a drag strip nearby, just go and jet to the best MPH.
Correct jetting for the cruise is more involved and will require a meter and some additional knowledge of the power circuit. And although this will cause some discussion, an inexpensive narrow band O2 will get you very close.
To be clear, I am recommending the narrow band for tuning only the cruise ratio right now.
Flame on..............
Master, again and still
Re: White Plugs Burning Lean?? [Re: DaveRS23] #1518198
10/16/13 01:17 PM
10/16/13 01:17 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
I will snap a picture of them tonight. The engine only had 300 miles on it and it dropped a cylinder so the engine shop rebuilt it again. Those plugs where white. The new plugs maybe have 75 miles on them. Still looking white.
This is a street car so it wont be doing much WOT, just cruising. One problem I have with it and why the jetting was suggested was first off the white plugs. Then there is the dead stop and hammering it. It bogs down big time until it seems to get into the main jets then takes off like a SOB. I also have my idle set at 800 and when put in gear it drops to about half that. I know the 268 cam has a somewhat loopy idle but I dont know if the jetting has anything to do with that.
If you guys think this is two different issues lets stick with the plugs first. I would like to make sure that is correct first.
Re: White Plugs Burning Lean?? [Re: weazel] #1518199
10/16/13 01:24 PM
10/16/13 01:24 PM
If you have hammer the throttle already it may make reading the plugs for part throttle impossible, go ahead and post the pictires ofthe ones in it now. If you can and want to then put in all new plugs and drive it around for 10 to 20 miles at part throttle with no hammering and post those later As already mentioned there are several different circiuts in Holley type carbs that can and do affect the sprak plug colors We need to know what brand and spark plug number also as well as the type of fuel, if it is E10 or E15 or non Ethanol If your willing to work on it and make it better we might as well work together and make it perfect
Re: White Plugs Burning Lean?? [Re: Cab_Burge] #1518200
10/16/13 01:49 PM
10/16/13 01:49 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
What did it do when you say it "dropped a cylinder"
Re: White Plugs Burning Lean?? [Re: weazel] #1518201
10/16/13 02:07 PM
10/16/13 02:07 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
No alarm bells going off here guys?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: White Plugs Burning Lean?? [Re: Rug_Trucker] #1518202
10/16/13 02:24 PM
10/16/13 02:24 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
sounds like a timing or advance problem (initial timing partly coming from advance, which drops when going into gear)
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: White Plugs Burning Lean?? [Re: Cab_Burge] #1518203
10/16/13 09:23 PM
10/16/13 09:23 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
I have pics of the plugs, but its very hard to tell the true color. I also noticed that not all the plugs where white. Some of them where actually the nice brownish color.
Also I shouldnt say that I hammered on the throttle but I did give it about half throttle to see if it would go. Otherwise it was cruising speed at 60-65.
This is a pic of the white plug.
Re: White Plugs Burning Lean?? [Re: weazel] #1518204
10/16/13 09:25 PM
10/16/13 09:25 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
There were only 3 plugs that were brownish and looked normal like this one.
Also the plugs are NGK ZFR6F. Im running 87 octane pump gas.
Re: White Plugs Burning Lean?? [Re: GTX MATT] #1518205
10/16/13 09:28 PM
10/16/13 09:28 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
The #6 cylinder had two broken piston rings, so the engine shop took it back and rebuilt it again.
Re: White Plugs Burning Lean?? [Re: Rug_Trucker] #1518206
10/16/13 09:37 PM
10/16/13 09:37 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
Care to elaborate with some useful info or being sarcastic about something?
Re: White Plugs Burning Lean?? [Re: VincentVega] #1518207
10/16/13 09:41 PM
10/16/13 09:41 PM
Oakdale, MN
W
weazel Offline OP
weazel  Offline OP
W
Oakdale, MN
I am thinking I may have a distributor problem also, but not entirely sure. I may start another thread about that, but Im more curious as to what you think about my plugs. From what you can tell with the pictures I posted.
Re: White Plugs Burning Lean?? [Re: weazel] #1518208
10/16/13 10:03 PM
10/16/13 10:03 PM
I think the remark was to illuminate the mechanical advance dropping back from say 10 degrees BTDC to say 4 degrees BTDC when put in gear, the less initial advance will make the motor drop more RPM when put in gear One of the accepted standards on RPM drop on initial timing and the mechanical ignition curve as well as setting the carb. up to idle on the idle circuit only is to have only 200 RPM drop from nuetral to in gear with a automatic trans that has a standard non racing converter, IE idles at 800 RPM in nuetral and drops to 600 RPM in gear The less initial advance you have at idle can lead to a bigger RPM drop if the total mechanical advance has to much in it IE if you have 13 degrees mechanical(26 total crankshaft degrees) advance in the distributor and you want to have 34 degees total advance you have to set the initial at 8 degrees BTDC, but if the distributor has 3 degrees mechanical advance in it at 800 RPM and drops 2 distributor degrees at 600 RPM you end up with 4 degrees initial in it at idle, most motors don't like to have 4 degrees advance at idle They do like 12 to 16 BTDC though at a 600 RPM idle speed Is that clear Lots of ways to make are hotrod motors run better, but it requires working on and modifying some of the parts to make them better
Re: White Plugs Burning Lean?? [Re: Cab_Burge] #1518209
10/16/13 10:28 PM
10/16/13 10:28 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Just for reference:
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
