? best Early A body headers w/big block???? #1518046
10/15/13 07:08 PM
10/15/13 07:08 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
who's running what?
Re: ? best Early A body headers w/big block???? [Re: Randy..] #1518047
10/15/13 07:49 PM
10/15/13 07:49 PM
gregsdart Online content
gregsdart  Online Content
There are no commercially available headers for an RB or B motor in an earlky A. There is so little room the best you can do for a SMALL BLOCK is 1 5/8 tubes, if you want to stay inside the frame rails.
First off, with an RB motor, the exhaust ports are right up next to the shock tower on the passenger side. So that has to be addressed. Your best option is to go low deck with a set of stock iron heads, or any head with the stock port location that isn't any wider. It doesn't hurt to go higher, as you will have to build these yourself, or have them built. The shock tower will probably need to be modified for pipe clearance, which means moving the shock mount out a touch. The next problem will be trying to fit all those tubes somewhere. It may take a full fenderwell set, or a two inside the frame, two wrapping the frame to make it work with the little space available.
Probably the best option is to go with a Mustang II front end. Not cheap (but about as cheap as a front conversion gets), but you will have a lot of room for the motor, and gain a lot of room for exhaust.
If you try and build a set of fender well headers, the best way is to keep all four tubes against the wheel well to save the turning radius. There isn't much room in there for a four square arrangement like you usually see.
Re: ? best Early A body headers w/big block???? [Re: Randy..] #1518048
10/15/13 08:22 PM
10/15/13 08:22 PM
What are you calling "early A body"
Re: ? best Early A body headers w/big block???? [Re: Cab_Burge] #1518049
10/15/13 09:12 PM
10/15/13 09:12 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
66 and earlier are my understanding of an early A
Re: ? best Early A body headers w/big block???? [Re: tubtar] #1518050
10/15/13 11:23 PM
10/15/13 11:23 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
this is correct Cab, fenderwells is all that is available for them, Hooker Pt# 5215 supposed to fit.
Re: ? best Early A body headers w/big block???? [Re: Randy..] #1518051
10/15/13 11:36 PM
10/15/13 11:36 PM
These are for a 67 or newer A body, with the wider frame rails. There are no available BB headers for the narrow early A Mopars.
Re: ? best Early A body headers w/big block???? [Re: gregsdart] #1518052
10/16/13 12:10 AM
10/16/13 12:10 AM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
jeg's web site is wrong then. need to just put a good sb in it and drive it.
Re: ? best Early A body headers w/big block???? [Re: Randy..] #1518053
10/16/13 04:00 AM
10/16/13 04:00 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have seen early A's with the fenderwell Hookers in them. It ain't pretty.
Re: ? best Early A body headers w/big block???? [Re: Randy..] #1518054
10/16/13 08:29 AM
10/16/13 08:29 AM
For a small block there are a couple of options. Visit FOR A BODIES ONLY web sight and go to early A's. There are both long tube and shortys made that will fit your car. There are sets of long tube fenderwell headers in 1 7/8 that fit a 1970 Cuda 340. I had a set, acquired from a guy that traded his smallblock stuff to me for my 440 race motor to put in his Cuda. I put them in my 65 Dart when I first got it with the small block 340. They are Hooker, slip together with different pipe length combinations, and 1 7/8 primarys. These would produce the most Hp if you are able to find a set. My idea of a cool early A is a stroker smallblock with a 440 cube size. You can say you have a 440, and you do. heads available for the small block are vastly superior to what came stock on a 440 BB, so you can make some very serious power.
