F or M body with big block?
#1517873
10/15/13 03:30 PM
10/15/13 03:30 PM
Posts: 1,106 Northeast
VincentVega
Northeast
Just curious if anyone here is running a big block in something like a Diplomat or Volare, with the stock suspension.
Does it become unsafe to drive with all that extra weight up front?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: F or M body with big block?
[Re: Diplomat360]
#1517875
10/15/13 04:50 PM
10/15/13 04:50 PM
VincentVega
Northeast
curiosity and money. I know it'd make a good drag setup but that's not how we use our cars. have a volare duster that's in pretty good shape, basically just a rolling chassis with rebuild front end. also have lots of BB stuff and a very low budget. Would be a nice way to get dad back into the game in his retirement years. but don't want it to be dangerous! I have an aluminum slant six for my diplomat
[Re: VincentVega]
#1517877
10/15/13 05:48 PM
10/15/13 05:48 PM
Posts: 596 Mass.
80fbody
Mass.
I say go for it. Will be a cool ride. I own an f body, 4speed car with approx 400hp smallblock. These cars are very stable & have a nice wide stance with a good wheel package. A few front end tweaks, an 8 1/4 posi rear & it will be a cool toy. First thing I'd do would be solid front bushings for the k-member, good kyb shocks, new tires & a good alignment.
The front bumpers & bumper shocks weigh a ton. Certainly a place to lighten up. I've done aluminum bumper brackets in the past.
[Re: 80fbody]
#1517878
10/15/13 06:00 PM
10/15/13 06:00 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Oh good lord.
Yes you can run a BB in an F/J/M body with the stock suspension.
[Re: VincentVega]
#1517879
10/15/13 08:15 PM
10/15/13 08:15 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I ran a 440 in an'77 Volare RR for nearly 32 years and it was a blast. Would I recommend it for everyone? Not when you can build a stroker sb.
There were no issues with the front suspension. The rear did not hook until I put a superstock spring suspension under it. There are other choices available for that as well.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: VincentVega]
#1517880
10/15/13 11:31 PM
10/15/13 11:31 PM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
I have a dealer demo kind of loaded 59k 80 Dippy coupe i intend to put a magnum headed early 318 w A500. im wondering what my best rear option is. eliminate iso-ride?
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger w 383 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1997 Ram B3500 Van 5.9 1991.5 W250 Cummins- Big Chief
[Re: 440PURSUIT]
#1517881
10/16/13 08:31 AM
10/16/13 08:31 AM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
I am running a stock K frame from a 5 th ave with stock t- bars in my 56 Plymouth ...I have am iron head 493 stroked 440 and have run it for 4 years now..I like everything about it...rides well on long trips . (When I change to the 2: 76 rear ).and runs well at 11.6 @ 115 mph .with 3:55 gear.the whole car weighs 3700 lbs.The only problem I had was the headers and the P/S box want to occupy the same space..but with a little heat and bending ,it works
[Re: Supercuda]
#1517882
10/16/13 12:59 PM
10/16/13 12:59 PM
Oh good lord.
I agree. Thats what this Mirada had in it, just a 10 second street car.
[Re: ]
#1517883
10/16/13 01:10 PM
10/16/13 01:10 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
It's just a big block, not a cummins diesel!
Stock for stock a big block is what? 150? 200 lbs heavier than a small block? Aluminum heads, intake, water pump housing, water pump, headers... And that big block weighs the same as an all stock/iron small block.
The front end will be fine.
**Photobucket sucks**
[Re: a12rag]
#1517885
10/16/13 03:35 PM
10/16/13 03:35 PM
VincentVega
Northeast
thanks for all the feedback.
and that sounds like a very nice setup, 440 with 518! how was it done? u ultrabell or adapter?
[Re: VincentVega]
#1517887
10/16/13 09:04 PM
10/16/13 09:04 PM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I suppose a follow-up question could be: how well will it handle with the stock T-bars and 440 in there?
All the posters are absolutely right...it sure can be done...but will it handle, will it be a street car that you have to adjust to as you shift between your daily driver and your project car, or are we talking here 1/4 mile cars that go 'straight'????
Put it this way, my coupe is completely re-done, all new parts, including Koni 5-way adjustable shocks (front & rear). They are a day & night difference as compared to a stock or even HD shocks. Yet, there I am with a 360 block up-front (iron heads) and boy, that front-end likes to 'float'. Already have the replacement K-frame biscuits too.
So...I like a car that handles like it's on 'rails'...LOL...and a stock T-bar isn't going to get you moving in that direction!
[Re: Diplomat360]
#1517888
10/16/13 09:17 PM
10/16/13 09:17 PM
racealittle
I had a 1.25 front cop swaybar on the car, no rear swaybar. The dreaded KYB front shocks and cheapie long 25" Monroe Pickup truck shocks on the rear. It took corners pretty good, the ride was great. It was a rougher ride with the small block and KYB's on all 4 corners, (also had the cop rear bar at the time). It really did handle great as a small block, but big torque is more fun sometimes.
[Re: Supercuda]
#1517890
10/17/13 01:10 PM
10/17/13 01:10 PM
VincentVega
Northeast
yeah, I know what you mean about the float. My slant six M body with "cop" t-bars (as far as I know they just used higher durometer bushings) and the big swaybars handled very well. Firm suspension at any speed, even at 85 and beyond. however my 79 318 lebaron rode like a cadillac. Not exactly inspiring to drive
I could imagine stepping up once more would make it a bit on the scary side. I like to at least have the ability for evasive maneuvers.
I think I've gotten the impression I need here. thanks for all the information
[Re: VincentVega]
#1517891
10/17/13 02:46 PM
10/17/13 02:46 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Pretty sure he used an adapter. He has diventa lots of hiway miles on it, and never heard him complain about the handling.
Don't think you are gonna get a canyon carver without heavy $$$$ investment. Am sure it will be acceptable with stock tbars and BB drivetrain.
