Air Shocks #1517817
10/15/13 01:17 PM
10/15/13 01:17 PM
London, England
JFChallenger440 Offline OP
London, England
I have air shocks on the rear of my 68 Charger, we tried to put some air in them but they are not going higher, just heard a bit of creaking but nothing else, any idea where to start looking for the problem ? Thanks
Re: Air Shocks [Re: JFChallenger440] #1517818
10/15/13 01:31 PM
10/15/13 01:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bad rubber bellows, bad air line. You need to stick your head under the car and listen for air leaks while someone tries to air up the shocks. Maybe they are up all the way already.
Re: Air Shocks [Re: JFChallenger440] #1517819
10/15/13 01:38 PM
10/15/13 01:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Start by replacing them. They are shot I'm sure, rotted out rubber.
Get some regular shocks and forget about air shocks.
Re: Air Shocks [Re: JFChallenger440] #1517820
10/15/13 04:16 PM
10/15/13 04:16 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Get rid of them, the upper shock mount structure below the trunk floor was not designed to hold the car up, which is what your doing.
Re: Air Shocks [Re: 71birdJ68] #1517821
10/15/13 05:16 PM
10/15/13 05:16 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
X2. If you want a higher lift on the rear, change the springs - don't jack it up with air shocks. The ride with them sucks too. I pulled them off of my Coronet and the ride is 1000x smoother.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Air Shocks [Re: stumpy] #1517822
10/15/13 06:50 PM
10/15/13 06:50 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
leak should be easy to find.unless its internal in the shock itself.air shocks always seem to get a good bashing around here.but not every one has money for new springs and shocks laying around.
Re: Air Shocks [Re: mcmopars] #1517823
10/16/13 09:58 AM
10/16/13 09:58 AM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
New rear shocks for my Coronet were $25 ea. Not a large investment. They are Monroe shocks. The KYBs are $75 each!
Re: Air Shocks [Re: mcmopars] #1517824
10/16/13 11:01 AM
10/16/13 11:01 AM
Cincinnati, Ohio
Cincinnati, Ohio
New shocks are less money than air shocks which can damage your car.
Re: Air Shocks [Re: Challenger 1] #1517825
10/16/13 07:58 PM
10/16/13 07:58 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
The parts stores sell just the replacement air hoses of the plastic tubing is split and leaking.
Re: Air Shocks [Re: Tom_440] #1517826
10/16/13 09:00 PM
10/16/13 09:00 PM
IN
ahy Offline
ahy  Offline
IN
My local spring shop charges $100 to add a full leaf to a set of rear springs. That usually increases height by ~1" along with spring rate. That's a lot easier on the car than air shocks as several have posted.
Re: Air Shocks [Re: ahy] #1517827
10/16/13 09:05 PM
10/16/13 09:05 PM
USA
b54406barrel Offline
USA
Air shocks!!! My gosh you might as well scrap it out right now!
Re: Air Shocks [Re: JFChallenger440] #1517828
10/17/13 09:03 AM
10/17/13 09:03 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Easy way to find the leak is to get a squirt bottle of water with some dish washing soap, air up the shocks and spray away.
NMCA NSS 67 Coronet
Re: Air Shocks [Re: Challenger 1] #1517829
10/17/13 05:23 PM
10/17/13 05:23 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
i agree,but if he using them to lift the rear for tire clearance.shocks alone will not help,and will need new springs as well.not to mention the ride with air shocks suck
Re: Air Shocks [Re: mcmopars] #1517830
10/18/13 08:56 AM
10/18/13 08:56 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Except to "firm" up your suspension, the use of air shocks means you have the wrong wheels and tires, your springs are either worn out or damaged... Just my 2 cents...
Re: Air Shocks [Re: JFChallenger440] #1517831
10/18/13 09:22 AM
10/18/13 09:22 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
my home compressor goes to 80 pounds and won't raise mine..I used my buddy's shop compressor and they went up fine...mine are rated at max 250psi but I needed a compressor set at 130.
