Decoding engine numbers #1517776
10/15/13 09:39 AM
10/15/13 09:39 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
Is there a web site to decode the numbers on the front of a 340? Here are the numbers CW34OP34490418 it has a production date of 6-29-70
Re: Decoding engine numbers [Re: jwmotors] #1517777
10/15/13 09:44 AM
10/15/13 09:44 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
CW34OP34490418
"C" (is actually a "G")
G = Model year (G series is 1971)
W = Windsor Ontario Engine Assembly Plant
340 = Cubic Inches
P = Premium Fuel
3449 = 10,000 day calendar assembly date = Wednesday January 6, 1971
0418 = Engine build sequence
Re: Decoding engine numbers [Re: ScottSmith_Harms] #1517778
10/15/13 10:09 AM
10/15/13 10:09 AM
NC
jwmotors Offline OP
jwmotors  Offline OP
NC
Thanks for your help.
Re: Decoding engine numbers [Re: jwmotors] #1517779
10/15/13 10:24 AM
10/15/13 10:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
as you can see by the reply above you found the website ...
