8 3/4 rear in a 1942 truck ? #1517707
10/14/13 11:09 PM
10/14/13 11:09 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
just picked up a 1942 dodge 1/2 ton truck. how much modification is needed to install a 8 3/4 rear out of a 69 b-body ?
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517708
10/15/13 09:56 AM
10/15/13 09:56 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
if it has leaf springs you will probably need to move the spring perches on the axel housing. if it has the skinny leaf springs(my 47 Desoto does) the only place I found the narrow perches was at tractor supply, in the trailer parts section.
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517709
10/15/13 01:11 PM
10/15/13 01:11 PM
E
earlymopar Offline
earlymopar  Offline
E
Depending on what it came from, you will likely need to have the rearend housing narrowed and axles cut and re-splined. Thats what I did with my 37 P/U. I would guess your track width is about the same.
Re: 8 3/4 rear in a 1942 truck ? [Re: earlymopar] #1517710
10/15/13 11:56 PM
10/15/13 11:56 PM
Shelby, Ohio
2
Shelby, Ohio
i measured the rear end in the truck and measured the b-body 8 3/4". the 8 3/4 is actually 1" shorter than the truck rear measuring from backing plate to backing plate.
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517711
10/18/13 10:57 PM
10/18/13 10:57 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the correct place to measure would be the axle flanges--where the wheel mounts on the studs----to many variables on backing plate offset or drum widths...
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517712
10/18/13 11:22 PM
10/18/13 11:22 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I have a Ford 8 inch out of a Torino in my 37, it's about perfect in width, it's also exactly the same width as the B body Dana 60 I'm swapping it out for eventually, so don't use one out of a truck or C body, they are too wide
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 8 3/4 rear in a 1942 truck ? [Re: AZ_A12_BEE] #1517713
10/21/13 12:12 AM
10/21/13 12:12 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
71-74 Mopar "B" body, 68-74 "C" body, and 66-74 truck all use the same 8 4/3 rear axle housing, only the perches are positioned differently. Any difference in the backing plate width is due to which brakes were used.
All "A" body, all 70-74 "E" body, all 66-70 "B" body, and all vans ("A" & "B: vans had different axles as well) used different 8 3/4 axle housings. Not counting any of the earlier tapper axle vehicles.
From narrowest to the widest:
"A" body (also small 5 on 4" bolt pattern)
66-70 "B" body (some think there was a difference between those 66-68 and those 69 & 70, but I believe the difference was in backing plate width & brakes)
"A" Van
70-74 "E" Body
71-74 "B", 66-74 "C", 66-74 truck
"B: van (also off set)
Gene
Re: 8 3/4 rear in a 1942 truck ? [Re: poorboy] #1517714
10/24/13 01:30 PM
10/24/13 01:30 PM
NE Iowa
Road_RunnerSteve Offline
NE Iowa
We put an 8 3/4 from a 68-70 charger in my dad's '40 pickup. Didn't even have to move the perches if I remember correctly.
Re: 8 3/4 rear in a 1942 truck ? [Re: Road_RunnerSteve] #1517715
10/28/13 10:49 PM
10/28/13 10:49 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I put a '78 D100 8.25 in mine. It bolted in with the shock mounts from the '78 and new U bolts of course.
Re: 8 3/4 rear in a 1942 truck ? [Re: DusterKrazy] #1517716
10/28/13 11:16 PM
10/28/13 11:16 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
You can use a truck rear end but then you have to use wheels with a lot of back space, I personally like to see more wheel with offset to the outside so a 68-70 B body rear end is better for my tastes, not my truck but you get the idea
Re: 8 3/4 rear in a 1942 truck ? [Re: AZ_A12_BEE] #1517717
10/28/13 11:21 PM
10/28/13 11:21 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
49 plymouth coupe here...
used a 68 B wagon 8.75 in mine. Had to weld on new perches. Good width...
EDIT 40, not 49!
Re: 8 3/4 rear in a 1942 truck ? [Re: RodStRace] #1517718
10/28/13 11:26 PM
10/28/13 11:26 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Welding perches is easy to do, I did it fixing my 37, they had 2 inch perches and the springs are 1.75 wide
Re: 8 3/4 rear in a 1942 truck ? [Re: AZ_A12_BEE] #1517719
11/15/13 12:03 AM
11/15/13 12:03 AM
Shelby, Ohio
2
Shelby, Ohio
finished mounting my 1969 b-body 8 3/4 rear tonight.has 3:91 gears. made all new spring hangers and shock mounts. rear leafs from a 69 barracuda.since i had to re-position the spring hangers, i had to make new frame cross members. made out of 2 1/2" thick walled stock.
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517720
11/15/13 12:06 AM
11/15/13 12:06 AM
Shelby, Ohio
2
Shelby, Ohio
and here is a picture of the finished job. perfect width. i also lowered the rear by 2". i will be lowering the front end about 3" with a fatman mustang 11 front. next i'll get started on installing my late model 360 magnum w/904.
Re: 8 3/4 rear in a 1942 truck ? [Re: 2abodymcodes] #1517721
11/15/13 12:18 AM
11/15/13 12:18 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Looks good, nice and clean
I'm pretty sure I will need to remove the cross member ahead of the rear axle when I do my 4 link, I think it's too close
Re: 8 3/4 rear in a 1942 truck ? [Re: AZ_A12_BEE] #1517722
11/17/13 03:43 AM
11/17/13 03:43 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
looks great
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
