68 barracuda trunk light, question #1517586
10/14/13 07:54 PM
10/14/13 07:54 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
my 68 fast back does not have a trunk light, i want to install one...
is there a hot wire dedicated to this already in the car, or do i have to run one from the front?
Re: 68 barracuda trunk light, question [Re: mcat4321] #1517587
10/14/13 08:17 PM
10/14/13 08:17 PM
You could T into the small filament taillight circuit (your running lights) so the trunk light would be hot anytime the park lights or headlights are on otherwise if you wanted the trunk light to be available anytime whether the running lights are on or not yes you'd have to run a wire up front & the closest point that is hot all the time would be the dome light or rear pillar lights if the car has them & the pink wire is the hot wire & on all the time
Re: 68 barracuda trunk light, question [Re: RapidRobert] #1517588
10/15/13 08:36 AM
10/15/13 08:36 AM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
here is a wiring diagram
