Wiring by BJS racing. Not mopar but still turned out ok
#1517250
10/14/13 11:44 AM
10/14/13 11:44 AM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
Turned out ok. There were a couple of spots I wasn't thrilled with but had to work with some of what was already done when I got it and they had already cut some so I couldn't redo it with out it looking like crap.
Back in the swing of things at Painless again! Great to be back!
Re: Wiring by BJS racing. Not mopar but still turned out ok
[Re: BJS racing]
#1517254
10/14/13 12:19 PM
10/14/13 12:19 PM
BJS racing
Arlington, Tx.
engine compartment. Did the plumbing on the car as well.
[Re: Triple Threat]
#1517259
10/14/13 02:03 PM
10/14/13 02:03 PM
BJS racing
Arlington, Tx.
That one is a K&R kit. It is what most everyone down here runs.
[Re: Triple Threat]
#1517261
10/14/13 02:47 PM
10/14/13 02:47 PM
BJS racing
Arlington, Tx.
I do like them. The only thing I don't like about them or the Digital delay kits is if anything happens to the board you have to replace the whole thing. You can't just replace a relay and be on your way. I helped design a set up here at painless years ago when I was here before that works really well but I was limited with what I could do and incorperate in the kit being that we don't use printed circuit boards. If I was going to wire a car for myself I would likely use the K&R delay box with their switch panel and board set up or their box with our harness. I like the Painless set up because if any thing happens to it you can fix it on the spot.
