Ignition #1517242
10/14/13 10:57 AM
10/14/13 10:57 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Anyone have the part number for the brass terminal, ribbed and vented distributer caps? Need one for a 383 single point dist and for a 318 w/ electronic ignition
Re: Ignition [Re: jeebis44] #1517243
10/15/13 12:37 PM
10/15/13 12:37 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Re: Ignition [Re: jeebis44] #1517244
10/16/13 04:24 AM
10/16/13 04:24 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
You need to re ask your question in a different way.
It sounds like you either want a generic dizzy cap in which case any chuckle head at vato zone can help you with, (the accels are the right tan color kinda sorta)
or
Your asking for NOS pieces in which case ebay is probably the place to start.
Just what your asking for isn't quite clear.
I can't afford this. mark
Re: Ignition [Re: a12superbee] #1517245
10/16/13 05:06 PM
10/16/13 05:06 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
I'm looking for the distributor cap that has:
Brass terminals, the concentric rings around each terminal on the inside of the cap, and also has a vent. I saw them years ago and am having a hard time finding them now.
Re: Ignition [Re: jeebis44] #1517246
10/16/13 05:40 PM
10/16/13 05:40 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Re: Ignition [Re: GTX MATT] #1517247
10/16/13 06:31 PM
10/16/13 06:31 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
That one on summit is missing the ribs. Here's a pic of what I'm talking about, except it's not brass and has no vent...
http://www.ebay.com/itm/NOS-58-66-Dodge-Dart-V8-Dual-Point-Distributor-Cap-440-/390047714978
Re: Ignition [Re: jeebis44] #1517248
10/16/13 07:49 PM
10/16/13 07:49 PM
(1) No but contact "joesixpack" on here & if anybody has one he will. (2) Might be the same piece
