BBM solid roller lifters #1517238
10/14/13 10:51 AM
10/14/13 10:51 AM
CO
N
Nitrojunkee Offline OP
N
CO
So I'm to the point in my build where I need to get some solid roller lifters this week, for my 496 Wedge build. It's a factory block, non bushed lifter bores, and a Bullet custom grind blower cam. Operating range of the cam is 3500-6500rpm. Thinking about going with the Crane Utra Pro's or maybe Morel.
What is everyone using?
Re: BBM solid roller lifters [Re: Nitrojunkee] #1517239
10/14/13 11:28 AM
10/14/13 11:28 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
After talking to Hughes Engines I bought their Solid Roller Lifters.
550lbs open pressure and spin the egine up to 6200rpm. after 650miles
everything looks like new.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: BBM solid roller lifters [Re: Den300] #1517240
10/14/13 11:38 AM
10/14/13 11:38 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
When it comes to roller lifter's buy good quality ones.Because if one comes apart it will just about destroy everything in your engine,before you can catch it.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: BBM solid roller lifters [Re: Nitrojunkee] #1517241
10/14/13 11:39 AM
10/14/13 11:39 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Check your PMs...
RIP Monte Smith
