Steering Column Install (Ground Jumper) #1517131
10/14/13 01:52 AM
10/14/13 01:52 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Installed my steering column and saw the service manual mentions installing a ground jumper from the column to the dash studs.
While it seems to make reasonable sense, I didn't have a ground jumper, checked my copious pictures and nothing.
So did all e-bodys have jumpers? perhaps AAR's didn't? or maybe this is a post 1970 thing?
Thanks for the information
Re: Steering Column Install (Ground Jumper) [Re: AAR#2] #1517132
10/14/13 02:43 AM
10/14/13 02:43 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
All old mopars of that era have one.
5th picture down on this thread shows one.
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: Steering Column Install (Ground Jumper) [Re: autoxcuda] #1517133
10/14/13 08:00 AM
10/14/13 08:00 AM
London, England
Gavin Offline
Gavin  Offline
London, England
I'm not sure E-Bodies did have them, I recall this being discussed in a previous post.
Let's put it like this, my 71 did not have one when I disassembled it, and had functioned perfectly well for my entire ownership like that.
When I put it all back together, I did make one anyway, I think with all the painting/coating of all the local components I had interrupted the ground path.
Re: Steering Column Install (Ground Jumper) [Re: AAR#2] #1517134
10/14/13 11:38 AM
10/14/13 11:38 AM
1970_EK2AAR Offline
1970_EK2AAR  Offline
The horn switch ground wire is only used on columns that require plastic "sliders" as part of the driver/impact design of the steering column support bracket. Since all E body bracket to dash attaching points are metal-to-metal, the horn ground is therefore achieved.
Re: Steering Column Install (Ground Jumper) [Re: 1970_EK2AAR] #1517135
10/14/13 11:56 AM
10/14/13 11:56 AM
Dry Heat AZ
AAR#2 Offline OP
AAR#2  Offline OP
Dry Heat AZ
Great, so as long as I do a validation of continuity between the column crush can (Folgers can) and the dash I should be good.
Wonder why the servise manual doesn't mention that grounding straps are not required for E-body's, perhaps just another oversight
Re: Steering Column Install (Ground Jumper) [Re: AAR#2] #1517136
10/14/13 09:56 PM
10/14/13 09:56 PM
1970_EK2AAR Offline
1970_EK2AAR  Offline
Between all '66 to '74 MOPAR models, the E body platform is the only design with columns that did not utilize the horn ground wire #2857741.
