what air cleaner will fit a 71 BB cuda with a RPM intak #1517110
10/14/13 01:32 AM
10/14/13 01:32 AM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
I just dropped a 431 stroker into a 71 cuda with a Edelbrock performer RPM intake and a Edelbrock thunder series AVS carb. With the hood off, it doesnt look like there is much room for an air cleaner,
any ideas?
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: mopar_leaner] #1517111
10/14/13 01:59 AM
10/14/13 01:59 AM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
Are you trying to make it look stock or is an after market air cleaner ok? Summit sells drop air cleaner so you could try there. Some guys were using a Ford brand drop air cleaner base that was the same size as the 68-69 unsilenced Chrysler air cleaner and they could use the top. But for 71 you had the dual snorkel.
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: 69rrgrabber] #1517112
10/14/13 09:00 AM
10/14/13 09:00 AM
Hermiston Oregon
Hermiston Oregon
non stock but it looks like i have maybe and inch or inch and a half to work with.
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: mopar_leaner] #1517113
10/14/13 10:06 AM
10/14/13 10:06 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You''l need a drop base air cleaner assembly with a 3" element , NOTHING factory is going to fit under a ralley hood.
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: JohnRR] #1517114
10/14/13 11:15 PM
10/14/13 11:15 PM
Hermiston Oregon
Hermiston Oregon
thats what I have and it looks like it won't fit.
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: mopar_leaner] #1517115
10/17/13 11:04 PM
10/17/13 11:04 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We had a drop base and a 2" air filter in a 73 Challenger (should be similar). Very restrictive though. Put clay 5 points on the lid (center and 4 points at edges) and close gently to see if there is clearance.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: what air cleaner will fit a 71 BB cuda with a RPM intak [Re: Dads426] #1517116
10/18/13 01:34 PM
10/18/13 01:34 PM
Hermiston Oregon
Hermiston Oregon
so maybe with a k and n x-treme top, we can get the airflow we need.
thank you!
