Mopar Performance/World Products Mega Block ? #1516782
10/13/13 03:40 PM
10/13/13 03:40 PM
Omaha, NE
dart69bigblock Offline OP
Omaha, NE
I am looking into getting a mega block for a project I'm working on. I have seen a lot of information on here about the Koleno, Indy Max and KB blocks but not the Mopar/ World iron blocks. Does anyone have experience with them. I am looking to build around a 500-540, E85, either twin turbo or procharged engine. Shooting for 1000hp at the crank to start and have room to improve. Going to be 75% street and 25% strip so I really don't think I need an aluminum block. Are the Mopar/World blocks good quality pieces? If they are descent is there any dealer that's better to deal with than others? Are there any otherr manufacturers out there that I'm missing? Any advice would be appreciated. Thanks
Chris
Re: Mopar Performance/World Products Mega Block ? [Re: dart69bigblock] #1516783
10/13/13 04:23 PM
10/13/13 04:23 PM
The World cast iron Mopar blocks are a fairly decent block for what your doing 1000 HP with either the blower or turbos on E85 is really easy to do I'm assuming it will be EFI also so you could probally make 1000 HP on E85 with EFI and two large throttle bodys N/A with a good set of heads also The key is the intake, exhaust, cam and C.I. and compression ratio for excellent results How fast do you want to go and how much traction due you have now?
Re: Mopar Performance/World Products Mega Block ? [Re: Cab_Burge] #1516784
10/13/13 05:26 PM
10/13/13 05:26 PM
Omaha, NE
Omaha, NE
I have not decided on EFI or blow thru yet. I have some of the stuff for EFI but would not have a problem with thru. It will have Caltracs and mono leaf in the back.
Re: Mopar Performance/World Products Mega Block ? [Re: dart69bigblock] #1516785
10/14/13 12:45 AM
10/14/13 12:45 AM
Me thinks you don't have good enough suspension for 1000 + HP What size and brand tires? Please don't tell me radials anything in any size
Re: Mopar Performance/World Products Mega Block ? [Re: Cab_Burge] #1516786
10/14/13 12:52 AM
10/14/13 12:52 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Locally
(Watertown, SD)
There is a car you might would like
Its a twin turbo big block Ragtop dart
Think its a 68 ?
All the Turbo stuff was done by Andy Wicks at Dynotune in watertown
Andy is very, very well known, does all kinds of wild builds and is well respected
http://www.dynotuneusa.com/DynotuneUSA/Welcome.html
Guy passed away, the car is pretty decent
His daughter is working on selling it
22k firm
It has a ton of good parts already
If you are interested I can find a phone #
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Mopar Performance/World Products Mega Block ? [Re: dart69bigblock] #1516787
10/14/13 12:16 PM
10/14/13 12:16 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
dart69bigblock
Mopar Muscle recently ran three articles on a blown alcohol hemi that I built using the World aluminum block. 1500 HP was no problem at less than 10 lbs of boost. Then I sold that engine to a fellow who wanted to step up. I tuned that engine last week on the dyno and it made over 1700 HP at 13 lbs of boost. No problem with the block.
I used all new ARP main studs, upgraded the head studs to L19 material, and pinned the cam bearings so they wouldn't move, but the block itself help up with no problem. The main caps showed some effects of "cap walking" but you would expect that at these power levels.
I would have preferred a KB but Ken was not able to ship quickly enough.
