SB Head dowels #1516598
10/13/13 08:38 AM
10/13/13 08:38 AM
Muncie
Racebuddy Offline OP
Muncie
Put together my 418 SB stroker. My machine shop removed the head dowels and didn't replace them after working on the block.
Will my head studs be enough to keep them straight or should I take the heads back off and install the head dowels?
I wasn't concerned about it until a Chevy guy last night told me about some trouble he had with no dowels and using bolts.
Just wondering, I'm wanting to drop motor in today.
GO OR NO-GO ???
Re: SB Head dowels [Re: Racebuddy] #1516599
10/13/13 08:53 AM
10/13/13 08:53 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Definitely need the dowels. Head bolts alone will not align the head.
Leon
Re: SB Head dowels [Re: Leon441] #1516600
10/13/13 08:59 AM
10/13/13 08:59 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
X2. You need them. And make REAL sure that they are deep enough that the head doesnt bottom out from it sticking up too high and hurting the head when you torque it down.
Re: SB Head dowels [Re: Leon441] #1516601
10/13/13 10:19 AM
10/13/13 10:19 AM
Muncie
Muncie
not using bolts, have studs in it.
I guess I already knew the answer to my problem before I posted my question.
Re: SB Head dowels [Re: Racebuddy] #1516602
10/13/13 01:29 PM
10/13/13 01:29 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Same happened to me. I got a dowel at Ace hardware and cut it down. Make sure it fits well in the head before driving it into the block. Don't ask how I know.
Yeah, it's got a smallblock.
