Ladder bar Adjustment?? #1516362
10/12/13 11:18 PM
10/12/13 11:18 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
When my car leaves the line with both front tires up off the ground it will go to the right just enough that I have to correct it. With a ladder bar set up what adjustment do I need to make? Thanks
Re: Ladder bar Adjustment?? [Re: bobs69] #1516363
10/12/13 11:40 PM
10/12/13 11:40 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
more preload on the passenger side
Re: Ladder bar Adjustment?? [Re: bobs69] #1516364
10/13/13 12:04 AM
10/13/13 12:04 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Ideally, I would recommend you set the car on scales. However, if the car is pulling right, it usually means the left tire is planting harder, driving the car to the right. Some additional "pre-load" on the right side will often correct this. On a 4-link, this would be done by shortening the top bar on the right side. Since the bottom bar on the ladder bar is the adjustable one on most ladder bar setups, I would lengthen it about 1/2 turn.
If the car is setting fairly level to start with, this "pre-load" may cause the right rear corner to raise up slightly. In turn the left front will drop (I would take ride height measurements at all four corners before making adjustments). Tightening the left torsion bar will correct this, and in turn add a little more pre-load, which is why I would only adjust the ladder bars 1/2 turn at a time.
Re: Ladder bar Adjustment?? [Re: ProStDodge] #1516365
10/13/13 10:05 AM
10/13/13 10:05 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
The first thing I would do is make sure the rear is square in the car.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Ladder bar Adjustment?? [Re: bobs69] #1516366
10/13/13 11:05 AM
10/13/13 11:05 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You always want to make sure if everything is square so you have a good baseline. The chassis will follow the housing if it's crooked. If a bracket is bent,crooked, or you have a collapsed spring it's better to know first. Scaling the car will get you in the ball park, but it is not a cure all. Track testing will ultimately tell you what you need. In your case preloading the right rear (making the bottom of the right bar longer) by a few flats will probably help.
Doug
Re: Ladder bar Adjustment?? [Re: dvw] #1516367
10/13/13 03:20 PM
10/13/13 03:20 PM
412 SB Duster Offline
We had this same problem, tried adding preload it didn't help. Started looking things over found the rear end had shifted over moving the ladder bars out of square. Ladder bars square car leaves straight again.
Re: Ladder bar Adjustment?? [Re: 412 SB Duster] #1516368
10/13/13 05:14 PM
10/13/13 05:14 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Putsomeone in the car with the same weight as you, and on passenger side make sure you have neutral preload. Meaning if you loosen up the nut on the front of the ladder bar it slides in and out without any tension. I bet your nut has a bunch of tension to it causing your car to move and not go straight.
Re: Ladder bar Adjustment?? [Re: Sammy] #1516369
10/13/13 10:38 PM
10/13/13 10:38 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I weigh about 20 pounds more than the guy I got the car from. We do have a set of scales we can put it on. When it goes to the right and I have to correct it. It will run about two off. Where we race if you run two off most of the time you are on the trailer. Thanks for the information.
