A518 RH/RE question #1516297
10/12/13 08:25 PM
10/12/13 08:25 PM
Western PA
O
OldMoparMan Offline OP
O
Western PA
I found a 1996 Ram 2wd today that I can get the tranny for a good price so my question is can I change the computer controlled RE valve body out for a RH valve body or are the cases different. This will be going into my Dart Sport over the winter.
If I'm reading right any tranny from 88 to 94 should be and RH but might I find a RH in a say 95 that was a left over.
Re: A518 RH/RE question [Re: OldMoparMan] #1516298
10/12/13 09:17 PM
10/12/13 09:17 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would say no---- re doesnt have a governer weight --re used elec connection for the OD and the rh activates with fluid pressure---i think the main shaft on the re has a machining difference too...
Re: A518 RH/RE question [Re: savoy64] #1516299
10/13/13 04:15 AM
10/13/13 04:15 AM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Correct, the RE lacks the mechanical governor needed with the RH valve body.
Re: A518 RH/RE question [Re: OldMoparMan] #1516300
10/13/13 08:59 AM
10/13/13 08:59 AM
Western PA
O
O
Western PA
I'll keep searching.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
