Re: A Teaser...
[Re: 1fastrunner]
#1515978
10/12/13 10:39 AM
10/12/13 10:39 AM
moparpollack
Lil Herman
Lil Herman
85086
Re: A Teaser...
[Re: Hotwheelsjr]
#1515981
10/13/13 10:39 PM
10/13/13 10:39 PM
moparpollack
Lil Herman
Lil Herman
85086
Color , motor, etc what are you gonna do with it?
Re: A Teaser...
[Re: moparpollack]
#1515982
10/15/13 11:52 PM
10/15/13 11:52 PM
Posts: 10,697 Surface of the Sun, AZ
Hotwheelsjr
Current plans are to get it back together and properly titled -- probably a satin black paint job, polished Torq Thrust IIs, 400 or 440 (nothing wild). It has a dismantled title -- I have to get it back on the road and go through inspection to get a good title back on it. I'm just in the early stages of collecting parts now -- it probably won't see the road for a year.
Re: '72 Satellite Becoming a '71 RR "Clone"
[Re: Hotwheelsjr]
#1515986
11/02/13 12:59 AM
11/02/13 12:59 AM
Hotwheelsjr
Ok...starting to dig into this thing now. The "right" coast guys are gonna hate, cuz haters gonna hate. Car was originally bought in Tucson and bounced back and forth between Tucson and Phoenix its entire life, so I'm told. It's definitely a southwest desert car...99% rust free. I drug it home from south of Tucson. Originally a 318 car. Plan is a big block...either a 400 or 440, of which I have both. Previous owner knew it had a 8.75 sure grip of sorts in it, possibly a spool...someone has definitely put some time and money into the rear, but I haven't dropped the pig yet to see what carrier it is. I did the "spin the wheels and count the yoke revolutions" the other day and it appears to have 3.91's in it. So, without further ado, here are some pics of what I'm starting with.
[Re: Hotwheelsjr]
#1515989
11/02/13 01:41 AM
11/02/13 01:41 AM
Wow.......pretty clean body, shouldn't take long.
[Re: ]
#1515990
11/02/13 01:51 AM
11/02/13 01:51 AM
Hotwheelsjr
Yeah, clean as a whistle. Length of time to fix 'er up will depend on my motivation.
[Re: Hotwheelsjr]
#1515992
11/02/13 10:46 AM
11/02/13 10:46 AM
Well the weather you have in Arizona during winter should be enough to motivate you no.............. This car should look good when done as you did a wonderful job on the cuda.
[Re: ]
#1515993
11/02/13 12:20 PM
11/02/13 12:20 PM
Hotwheelsjr
Ty sir.
The plan is to get some more blasting done today...hopefully the entire front clip minus the suspension -- those will get done when I pull it all off the car to do a disc brake swap (it has 4-wheel drums now). The inner fenders and firewall should go pretty quick -- the old paint is blasting off very easily.
