Re: OBD II Code readers
[Re: Runnin74]
#151572
11/16/08 12:27 PM
11/16/08 12:27 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
A reader does just that.It tells you the codes.You need a scanner to see live data.The reader just tell you what set a code like the O2 or emissions.Scanners used can be bought but most need updates for newer cars as they come out.Expect to paty probally 600 bucks for a decent used scanner.Then if it needsa updates they cost also.Rocky
Chrysler Firepower
[Re: wildman340]
#151575
11/17/08 08:53 AM
11/17/08 08:53 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I have a cheapie Actron scanner. I thought it told me the whole story. Turns out chryslers will read off the codes in the Odometer if you quickly go off to run 3 times.
The car showed more codes than the scanner and also I found that the scanner showed codes the car didn't!!
I keep it because it still erases codes OK.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: Jim_Lusk]
#151577
11/20/08 11:26 PM
11/20/08 11:26 PM
Posts: 556 Arkansas
GregGarner
Arkansas
I've seen some USB scanner/code readers and Linux drivers for them. Does anyone know which one of these scanners work well?
GregGarner www.rt-eng.com Home of the mopar solid state limiter adn tach repair kit
[Re: Runnin74]
#151580
11/21/08 09:19 PM
11/21/08 09:19 PM
You may want to look at a Scangauge. They work as a scanner, but can also be run continuosly as a selectable gauge. I am going to get on for the new campervan to monitor rpm, trans temp, etc as this thing is hauling around 9K pounds. $160 on Amazon, free shipping. http://www.scangauge.com/
[Re: AARCONV]
#151581
11/23/08 08:12 PM
11/23/08 08:12 PM
Posts: 1,755 Washington Twp., Southern NJ
Fastfrankie
without getting 2 crazy on brands and price, I bought the newest actron scanner out there...
I did the same. A guy sold me a brand new Actron he claimed was given to him as a gift - I'm sure it was a five fingered discount. I bought the Actron 9180 in the sealed plastic box for $60. I believe it retails for $135. I also have a Snap On MT2500 updated to 2003 and does up to 2008 global...
