k frame dissassembly.......
#1515705
10/12/13 12:47 AM
10/12/13 12:47 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Took the front end out from a 72 charger to later rebuild and reinstall into 70 cuda have everthing apart...except where the lower control arm goes on control arm is off but there is a bushing/shell on one side with a stud/nut on the other side how do you get this apart? do i save any of this?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: k frame dissassembly.......
[Re: toplescuda]
#1515707
10/12/13 11:20 AM
10/12/13 11:20 AM
RapidRobert
X2 on welding a washer on. It'd cost a bit plus the trips to the welder but trust me it's well worth it & if you try to get it out any other way you will regret it. I'm assuming you are going with OE type LCA bushings (recommended) rather than poly so yes the can outer shell does have to come out as it is part of the new bushing
[Re: toplescuda]
#1515709
10/23/13 07:14 PM
10/23/13 07:14 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
This is what im need to get off pass side seams to have a shell or something still on and the whole thing will turn i the k frame driver side wont spin pic is of pass side
[Re: Jim_Lusk]
#1515712
10/23/13 08:04 PM
10/23/13 08:04 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
The driver side dont have a shell on it what do i need to do with that side? do i have to remove it?? the pass side the whole thing spins in the k frame driver side (no shell) none of it turns
[Re: Stanton]
#1515714
10/23/13 10:42 PM
10/23/13 10:42 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I take it the threaded end needs to come past the k frame and.out though the shell? will be using a rubber frontend does the new parts come with shells?
[Re: toplescuda]
#1515718
10/24/13 11:09 AM
10/24/13 11:09 AM
Posts: 7,365 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I know this wasn't the OP's question but I read a cool trick on FABO that I'm going to use on my Dart. It seems way easier then welding a washer to the bushing shell.
I purchased an 1 3/8"(I think) tap for $12 on E-bay. What you do is clamp the tap in a vise and screw the LCA onto it. Then you just press against the tap.
I assume an E and B body would require a larger tap but it should still work the same.
[Re: burdar]
#1515719
10/24/13 11:41 AM
10/24/13 11:41 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Nope, all the LCA bushings are the same on A/B/E cars. I also bought a tap, but I have yet to use it...
[Re: Stanton]
#1515721
10/24/13 11:43 AM
10/24/13 11:43 AM
Jim_Lusk
Fresno, CA
Not a bad idea ... if you're lucky enough to find a cheap tap, pay shipping and wait a few days for it to arrive then never need it again. How many LCA's would a guy do in their lifetime ?!?!?
The washer trick is quick and simple and guaranteed to work. If you don't own a welder there's usually a shop nearby that has one - and will usually weld the washers on for a coffee.
Not knocking your idea, just saying that the "KISS" principle is usually best.
How many LCAs?? I've probably done 30 or so...
[Re: burdar]
#1515723
10/24/13 12:05 PM
10/24/13 12:05 PM
Posts: 1,106 Northeast
VincentVega
Northeast
we did the tap on a 73 B body. worked great
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
