Yet another crazy gasket removal (roloc) thread
#1515596
10/11/13 07:00 PM
10/11/13 07:00 PM
Posts: 2,091 Delray beach, Florida
Performance Only
Just to reiterate the point I was trying to make in the other thread, here's a few more pictures of a different job that came in. This time I got the actual culprit that did the dirty deed. Look familiar?
machine shop owner and engine builder
Re: Yet another crazy gasket removal (roloc) thread
[Re: Performance Only]
#1515599
10/11/13 07:06 PM
10/11/13 07:06 PM
Performance Only
I could already tell this was going to be bad, so I set it up on the machine and cut .020 for the first pass. Here's what it looked like afterwards. Notice that the water passages are intersecting the chamber in at least one spot.
#1515600
10/11/13 07:09 PM
10/11/13 07:09 PM
Performance Only
At this point I'm looking up parts to see what thickness head saver shim is available for this thing. The straight edge is tell me we need another .020+" to clean it up. Here's the next cut. @.040" total
#1515602
10/11/13 07:17 PM
10/11/13 07:17 PM
Performance Only
At this point it looks like .005 more will make it flat, so a little change on the feed and speed for a proper finish and voila. Just for the record, the customer was replacing the short block, cleaned up the head and bolted it on, only to find he now had water in the new short block. Hmm, I wonder why. After he saw first hand the damage he did he swears he'll never use a roloc disc again, ever. I figure what the heck, it's only money, right? Anyway, like I said before, I see this all the time. It's not like these are isolated incidents. Your results may vary.
#1515606
10/11/13 09:12 PM
10/11/13 09:12 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Dan, if you can convince these guys to not use the 'cookies',,can you get them to keep their pants pulled up where their underwear doesn't show, put their hats on straight, and not waste their engine $$$$$ on tatoos???
If you like drag racing, support your local track.
[Re: CHAPPER]
#1515607
10/11/13 09:38 PM
10/11/13 09:38 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have a 6.1 head that some moron did that too. He figured "hey at least the carbon is gone"......does anyone need a 6.1 head too practice on?
Mopar to the bone!!!
[Re: CHAPPER]
#1515608
10/11/13 09:59 PM
10/11/13 09:59 PM
Performance Only
Sure, just point them out.
#1515610
10/11/13 10:09 PM
10/11/13 10:09 PM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Yeah, it alway's looks like that on aluminum. I hope nobody takes this the wrong way, but those cookies sure do help my bottom line.
What do you suggest using to clean a head and block whether iron or aluminum for a head gasket change.
[Re: CHAPPER]
#1515611
10/11/13 10:21 PM
10/11/13 10:21 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
good luck You ask one why and they'll tell you "It's the way I choose to dress, I'm not copying ANYONE! I'm unique"
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: CHAPPER]
#1515613
10/11/13 11:56 PM
10/11/13 11:56 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Here's a better angle.
THAT is what "scuffy cookie" damage looks like!!
THAT is a better example.
[Re: Sport440]
#1515614
10/12/13 12:07 AM
10/12/13 12:07 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Definitely interesting information! Here's an idea... Maybe one of the guys who claim that only idiots and amateurs are causing damage with abrasive rotary pads, and that it can be done safely without damage to metal... Should send an example of their work in for inspection with the blue dye and a 'kiss' from the decking machine to check their work. Kind of a 'put your money where your mouth is' proposal.
**Photobucket sucks**
[Re: 70Cuda383]
#1515615
10/12/13 01:01 AM
10/12/13 01:01 AM
Performance Only
Here's an idea...
I've had plenty of people over the years tell me they were real careful when they removed the gaskets with a die grinder and a roloc/scotchbrite type pad. They're usually pretty shocked at what shows up on the surface. It doesn't matter how careful you are, they all remove metal and some are worse than others. Every type I've ever seen will round corners before the flat area's are free of the gasket. If that flat area is between the cylinders or combustion chambers, the pictures I've posted will prove what I just said. Some people even think they're making the surface better because it looks smooth and shiny when they're done. When the pads are new, they're very aggressive and cut a trough, after the pad starts to wear and become more flexible, people have to press down harder and use more of the middle of the pad,. that's when the corners or edges start to get rounded off. Again, that's usually a cylinder wall or a combustion chamber or a water jacket, etc. In any case, they're a great tool in certain situations, but not good at all when it comes to cylinder heads or engine block deck surfaces. In the case above, that head had to be cut .045" to be flat and a head saver shim was ordered to correct the height back to normal. Fortunately the shim was available or the head would've needed to be replaced. The way I see it, Our favorite Mopar engine blocks are starting to dwindle down. They only made just so many and when they're gone, we'll be looking for them in just about any form so we can build another engine to our liking. Don't destroy what we have left for the sake of a little elbow grease or a little extra time and care simply to remove some old gaskets. It's bad enough those factory blocks look like they were machined with a stone axe, don't make it any worse, please.
