Time for wheelie bars
#1515580
10/11/13 06:35 PM
10/11/13 06:35 PM
Posts: 617 Corvallis,OR
540CUDA
super street
super street
Corvallis,OR
Got some good bite last time out. Whos wheelie bars should I be looking at? The RJ racing stuff looks nice.Opinions please. And no .. the oil pan didnt survive
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Time for wheelie bars
[Re: 540CUDA]
#1515582
10/11/13 08:18 PM
10/11/13 08:18 PM
Posts: 1,770 Pa
Wv68charger
Pa
What was you 60' on that pass? What kind of pan were you running? Love your ride
[Re: Sammy]
#1515585
10/11/13 09:59 PM
10/11/13 09:59 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Skinny Kid Race cars out of Michigan is what I use.
80" wheelie bars from Skinny Kid
[Re: Wv68charger]
#1515586
10/11/13 11:28 PM
10/11/13 11:28 PM
540CUDA
super street
super street
Corvallis,OR
The timeslip said 1.004 for the 60'. Im not sure thats possible. It was a modified Charlies 10qt dragster pan. 1" too deep. Thanks for the info. Here's a pic near the 60ft timer.
[Re: topside]
#1515588
10/12/13 12:53 AM
10/12/13 12:53 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Keep your foot in it and keep shifting Pans usually get crunched by lifting while wheels up
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Dyno Donnie]
#1515590
10/12/13 09:22 AM
10/12/13 09:22 AM
Posts: 872 NJ
SSDAcuda
NJ
Santhuff front shocks and four link adjustment, but thats me... We're allowed a max of 48" bars and at that point it'll unload the chassis so above suggestion become necessary.
SS/DA 1924
[Re: Quicktree]
#1515593
10/12/13 10:52 AM
10/12/13 10:52 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
If your oil pan did not survive no higher wheelie than that you must have let out, broke, or shifted into high. Hey we all have been there. Well I never lift unless the wall is approaching. But, I have broke something and slammed the car down pretty hard. I keep telling people them ole cheap traction bar snubbers bolted in place of the stock lower control arm bumps is a great insurance policy.
I would try adjusting the car for a longer/lower IC. A 60" wheelie bar works well. Don't be mislead wheelie bars although used for wheelie limiting are best suited for controlling the load on the rear tire. In situations where you can only run a 48" they need to be spring loaded to keep from suddenly unloading the rear tire.
Judging from the car pictured I'm pretty sure you staged with the rear tires to get that 60 ft time. If that is your true 60 ft I would not change a thing other than lifting. Ride that baby to the 330 if you are 60 ft-ing 1.0's.
Leon
[Re: dvw]
#1515595
10/12/13 04:23 PM
10/12/13 04:23 PM
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
