518 TRANS WILL NOT WORK (HELP) #1515548
10/11/13 05:56 PM
10/11/13 05:56 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
91 DODGE DIESEL 518 OD TRANS
REBUILT MY TRANS AND NOW IT WILL NOT MOVE
INSTALLED SUNCOAST BILLIT CONVERTER AND A&A VALVE BODY WITH A HD CLUTCH KIT.
I HAVE REBUILT OVER 100 OF THESE TRANSMISSIONS AND NEVER HAD THIS PROMLEM.
THERE IS PRESSURE TO THE FRONT AND REAR SERVOS
PROBLEM SOLVED
WRONG PUMP,PUMP HAD 3 CHECK BALLS.
NEED PUMP WITH 2 CHECK BALLS
Re: TRANS WILL NOT WORK [Re: BUBBAZ572] #1515549
10/11/13 08:34 PM
10/11/13 08:34 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
check to see if manuel valve is hooked to shift liver arm ?
pump ear sheared ?
Re: TRANS WILL NOT WORK [Re: calrobb2000] #1515550
10/12/13 10:24 AM
10/12/13 10:24 AM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
YEA ITS ON
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515551
10/12/13 10:26 AM
10/12/13 10:26 AM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
PUT A STOCK VALVE BODY IN LAST NIGHT, STILL WILL NOT MOVE!
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515552
10/12/13 11:33 AM
10/12/13 11:33 AM
What about doing all of the air pressure checks with the rubber tipped air nozzle. From what I gathered you did do that for the servos & are there any other air checks that can be done? Otherwise it looks like it has to come back out
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515553
10/12/13 12:18 PM
10/12/13 12:18 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
4x4?
Re: 518 TRANS WILL NOT WORK (HELP) [Re: d-150] #1515554
10/12/13 01:57 PM
10/12/13 01:57 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
ya. do the air checks as Robert mentioned.. possibly torn seal... you can do the air checks with the VB removed
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515555
10/12/13 02:34 PM
10/12/13 02:34 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
I DID ALL OF THE AIR CHECKS.CLUTCH PACKS ARE GOOD.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515556
10/12/13 05:44 PM
10/12/13 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is pressure at the front and rear servos but how much pressure?
Even with broken drive tangs a pump can put out some pressure but not much.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: John_Kunkel] #1515557
10/14/13 12:06 AM
10/14/13 12:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree you need to know how much the fluid pressure is. What about manual low ? Will it move at all in manual low ? Ron
Re: 518 TRANS WILL NOT WORK (HELP) [Re: 383man] #1515558
10/14/13 02:13 PM
10/14/13 02:13 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
135 PSI FRONT SERVO
165 PSI REAR SERVO
WILL NOT MOVE IN ANY GEAR
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515559
10/14/13 03:02 PM
10/14/13 03:02 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
2 wheel drive tyranny
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515560
10/14/13 03:18 PM
10/14/13 03:18 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
If you are sure there are no issues in the overdrive section (e.g. problem with the direct clutch) then it's likely at the input end. Possibly a problem with the input spline on the new converter or an issue with the input shaft itself.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: PC-CHARGER] #1515561
10/14/13 04:13 PM
10/14/13 04:13 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
Torque convertor? Just because it is new, does not mean it was built correctly. That is basically all that is left.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: Bumbalawski] #1515562
10/14/13 04:53 PM
10/14/13 04:53 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
4X4 TRANS
I WAS THINKING CONVERTER ALSO
TOOK THE OD ASSEMBLY OFF TO DOUBLE CHECK IT.EVERYTHING IS OK
WHEN I REMOVED THE VALVE BODY I ONLY GOT A PINT OF FLUID DRAINING FROM TRANS. I DONT BELIEVE THE CONVERTER IS FILLING UP ON FLUID.IPUT 13 QUARTS IN AND SHOW FULL.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: PC-CHARGER] #1515563
10/14/13 05:26 PM
10/14/13 05:26 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
I'm thinking exactly as you on the direct clutch in the OD unit possibility. No direct clutch means no go....If he's got servo pressure then the pump must be doing something.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: superwrench] #1515564
10/14/13 06:07 PM
10/14/13 06:07 PM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
I know this is not your problem, but I remember of a fellow changed who the tranny in his 4X4 some years ago. It was in the garage sitting on level ground and would not move. He about went crazy. He called and told me what was going on with it. When he said it "raked gears" going into park, I knew what it was. Simple fix. He had his transfer case in neutral.
Re: 518 TRANS WILL NOT WORK (HELP) [Re: Bumbalawski] #1515565
10/14/13 08:04 PM
10/14/13 08:04 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
that was what i was getting at did same thing.you have to put transfer case in neutral to get shift lever off
Re: 518 TRANS WILL NOT WORK (HELP) [Re: BUBBAZ572] #1515566
10/14/13 08:49 PM
10/14/13 08:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Did you disassemble the VB? If so, did you get the selector lever back on the valve?
OOPS!!
I guess you did. If not, you wouldn't have pressure at the servos.
Perhaps a sprag failure allowing the guts to spin? Maybe dropped the link on the bands?
- Stu Harmon
Re: 518 TRANS WILL NOT WORK (HELP) [Re: superwrench] #1515567
10/15/13 05:57 PM
10/15/13 05:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I thought about the direct clutch but I dont believe it will cause his problem because there is an overrunning clutch in the overdrive unit that holds if the direct clutch slips. It is there so you dont get and rpm flare on the 3rd to overdrive shift when the direct clutch lets go and overdrive clutch comes in.
I had a problem once where the 518 trans would slip in reverse but not drive and it had just been rebuilt by one of our techs. I found out he left a disc out of the direct clutch but it did not slip in drive just reverse because the overrunning clutch held in drive and in reverse it does not hold of course as the power goes thru just the direct clutch. It so happened this trans had updated parts and called for one more clutch disc but the tech did not count how many disc he took out and put back what the manual said as the update was a TSB. Ron
