Dyno tuned my 5.7 hemi hilborn today - 415 rwhp #1515534
10/11/13 05:36 PM
10/11/13 05:36 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Finally dyno tuned my motor today. I'm very pleased. Picked the car up A LOT driving it home.
Quick breakdown:
1973 plymouth duster
forged 5.7, 11.6:1 compression, 03-08 GTP Extreme heads, Hilborn intake, custom shorty headers welded by me (around P/S box), 218/224 on 113.5+2 (xfi exhaust lobes- very mild)
TKO600 standard tranny, ford 9" floater rear, 3.60:1 gear with locker, heavy wheels all around.
Megasquirt 3x engine management tuned by me.
straight 30 weight conventional oil for all pulls.
We started the day in the 370's (rwhp) using a modified stock 5.7 timing curve. We kept adding timing until it dropped power, and backed it down 2* to the previous higher point. Ended up with more timing in the higher rpm range than most. I wanted more peak torque, but I am very pleased with where we ended up. ~300 rwtq from 3,000-7,000 will do just perfect for road racing.
added: Mustang Dyno
All on 93 octane unleaded. No knock sensors. Craig at Bumbera's was listening, and I was doing the same through a microphone clipped to the knock sensor point on the block. Neither of us heard any knock the entire day, including when we tried 2* on top of our final curve just because (dropped power across the board, did not knock though).
Honestly, I did not expect the motor to pull this high with this little cam. I expected the hp peak to be below 6000 rpm, as that's where this cam peaked on 5.7's & 6.1's with a normal intake. Guess not with my build.
A couple back to back runs at the end:
And my timing curve. DON'T YOU DARE use this curve and expect it to work - way too much timing for most - you'll blow your motor
Point worth noting: I marked TDC on my balancer and put my timing light on the motor to verify what the MS3x is commanding is what the motor is seeing. I found 1-2* of retard (light vs commanded) at 15-18*. That is within the range of measurement error, though it's very possible that the engine sees timing at 10% less than commanded. All I want you to take away from this curve is adding timing after peak torque was VERY beneficial for my motor. Further, this is the actual MBT for my motor on 93 octane, and MBT was reached before knock. Every motor is different so what worked on mine may not work on yours. Disclaimer: I'm not liable if you blow your motor trying to run 30*+.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Uhcoog1] #1515535
10/11/13 05:45 PM
10/11/13 05:45 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Awesome!
Mopar to the bone!!!
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: 72Swinger] #1515536
10/11/13 05:45 PM
10/11/13 05:45 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Car & Motor:
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: 72Swinger] #1515537
10/11/13 07:08 PM
10/11/13 07:08 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Nice build, what do you have for suspension and what size wheels do you have.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Uhcoog1] #1515538
10/11/13 08:30 PM
10/11/13 08:30 PM
If I didn't know any better, I would say your about half serious about this road racing deal Nice results
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Uhcoog1] #1515539
10/12/13 06:55 AM
10/12/13 06:55 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Very cool car!
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: ProSport] #1515540
10/12/13 09:43 AM
10/12/13 09:43 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
damn, that is cool
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: sixpackgut] #1515541
10/12/13 01:48 PM
10/12/13 01:48 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Good looking car and good numbers from the 5.7
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Silver70] #1515542
10/12/13 06:14 PM
10/12/13 06:14 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
Great looking machine!
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Dave_S] #1515543
10/12/13 06:25 PM
10/12/13 06:25 PM
MN
hemidup Offline
hemidup  Offline
MN
Nice, very nice!
Jerry Williams.
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: hemidup] #1515544
10/12/13 08:35 PM
10/12/13 08:35 PM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
Thanks fellas!
The suspension is set up for road racing. 1.04 TB's, road race leaf springs, front and rear sway bars, RCD shocks. Wheels are 18x9.5, with 265/40/18's.
I'll have it on the drag strip next weekend, the Texas mile a week after that, and the road course a month after that.
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Uhcoog1] #1515545
10/12/13 11:55 PM
10/12/13 11:55 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Why would a different intake make such a big difference in how much timing your particular engine could take? Most guys seem to make best power in the 20-24 degree range. Isn't it ususally the chamber design that has the bigger effect on timing?
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: Uhcoog1] #1515546
10/13/13 12:06 AM
10/13/13 12:06 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Thanks fellas!
Awesome, sound like your going to be busy. Good luck keep us posted on how see does in the different events. You running the car the same in all the events?
Re: Dyno tuned my 5.7 hemi hilborn today - 415 rwhp [Re: 1967dartgt] #1515547
10/13/13 04:47 AM
10/13/13 04:47 AM
Houston Tx
Uhcoog1 Offline OP
Uhcoog1  Offline OP
Houston Tx
I'm sure someone else has more first hand knowledge of this, but yes, I agree with you, the chamber has the most affect on required timing.
Looking at my timing:
Only up to 25* at 5000 rpm. 27* @ 5500, more after that. So really, the high timing was mostly all after peak efficiency, which falls in line with general tuning consensus.
-the 03-08 open chamber 5.7 head typically wants more timing than a closed chamber Apache or Eagle head. ~24 degrees or so vs 20 degrees or so.
*this cam peaks tq at ~4400 in a 5.7 LX with ported heads and bolt ons. The intake moved that north by 1000 rpm. One could argue that plays into the equation on timing required vs peak efficiency, etc
**my timing could be up to 10% off, given my crude TDC mark and testing from the day before. Real point in showing the timing table was to show how much advance it liked after peak torque.
Awesome, sound like your going to be busy. Good luck keep us posted on how she does in the different events. You running the car the same in all the events?
The plan is to keep it in road race trim for all 3 events, same gearing and all. Though a 150 shot of nitrous will be used on the first two.
